New Firmware 3.07 for MōVI M10
Discussion in 'MōVI M10' started by Tabb Firchau, Mar 27, 2014.
  1. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Hi Guys, we are pre-releasing this on the forums. Here is a new FW which addresses some issues and adds some new features. Important points to note:
    New features:
    Pan Trim
    Pan trim allows the user to adjust the center point of the pan axis via the GUI. For MR setups this will now give you the ability to fly in handheld pan majestic mode, allowing for smooth panning while flying as a single operator. Previously the center was off due to the difference in handheld vs. MR mounting.
    Motion Booting
    Previous firmware made it difficult for a clean boot-up of the MōVI during any kind of motion. An internal gyroscope self-test procedure is now bypassed when Motion Booting is set to ON. For use in situations where the MōVI needs to be initialized while gently moving, such as use on boats.
    Minimum pan/tilt rates seto to 1% of max slew speed
    Depending on radio type (Futaba versus Spektrum), slew rate limiting control could be set to zero in one case and for the other a slow slew was achieved. The firmware has been corrected to make both radios operate in a similar way with the minimal slew rate at 1% of the maximum slew rate limiter setting. This will allow very slow slew with full stick, for instance a coordinated move where the operator uses the slew limiter to adjust speed and stick to mainly adjust the direction.
    Improved kill time when kill switch activated
    Under certain conditions where a quick shut down is required, this has been made faster. The shutdown is still sequenced to help reduce unwanted swinging for an unbalanced gimbal.
    Shaky Cam
    Adds an adjustable amount of camera movement while operating the MōVI. This function senses the amount of movement in the gimbal and adds some of that signal back into the motors. Adjustable from -100% to +100% in both Pan and Tilt.
    Improved low temperature battery voltage cutoff
    A voltage cutoff adjustment was made to allow the MōVI to continue to operate where it previously may shutdown such as in cold weather due to battery temperature.
    Tilt remains in last known position in the event of radio signal loss
    Previously in the event of a brief signal loss the MōVI would return to level tilt and Majestic Mode. Now tilt will remain in the last known position and therefore be less likely to ruin a shot.
    Here is a link: http://bit.ly/1h0s0bF to a zip file for download that includes:
    • Instructions for Mac update
    • Instructions for Android Update
    • Instructions for PC update
    • MōVI 3.07 FW file
    • FW update feature list
    Please be sure to read the instructions in their entirety. Any questions fire away.
    Thanks!
    Tabb
  2. Austin Glass
    Austin Glass Active Member
    Aug 1, 2013
    440
    69
    I wish I would have seen this before I left on my non-Movi job, as now I have to wait until I get home to play with this! :(
  3. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    Just FYI for any M5 owners that wander into this thread... All M5s shipped with the updated 3.07 firmware so there is no need to upgrade.
  4. Steve Maller
    3,979
    Funny, for a day or so we M5 guys had some bragging rights over the M10 guys. Oh well. :rolleyes:
    Chris Daidone likes this.
  5. Chris Daidone
    Chris Daidone Member
    Jan 6, 2014
    142
    Perfect!!! I was just going to inquire about M10 firmware update progress.... You must have read my mind.
  6. Daisuke Ide
    Daisuke Ide Distributor
    Jul 26, 2012
    34
    Hi Tabb,
    Where the app do you operate this function?
    Motion Booting
    Thanks,
    Daisuke
  7. Gary Haynes
    Daisuke
    It is under Expert Mode, should be the first item.
  8. Angus Benson-Blair
    Jan 23, 2013
    148
    25
    Tabb, does this firmware include the ability to reset the gimbal if it futts out without having to land it- ie remote reset?
  9. Brett Harrison
    Brett Harrison Active Member
    Apr 7, 2013
    299
    40
    Very handy and smart upgrades.
  10. Joe Lawry
    Joe Lawry Member
    Sep 9, 2013
    42
    Thanks Tabb!
  11. Gary Haynes
    Also the Radio Bind feature has been added to the Android and Mac OS versions. Previously it was only in the PC version.
  12. James Michaels
    James Michaels New Member
    Mar 26, 2014
    25
    Just ran the FW update, now the MoVI won't stabilize. Turning it on, it blinks three lights very quickly once, then goes to one blinking light about 4 times, then all three come on and stay on. But no stabilization. Any thoughts on what happened?
  13. Gary Haynes
    Just a guess. Did you save and then reload the settings? Try the update again. If those two things don't fix it shoot an email to support@freefly.com.
  14. James Michaels
    Mar 26, 2014
    25
    I just got it, so I didn't have any settings saved. Are those settings just specific to how I had it set up? Shouldn't it default to system settings?
  15. Chris McKechnie
    Feb 26, 2014
    33
    I can't seem to get the update firmware to pop up under system. What am I doing wrong? How do I write that specific folder structure on the tablet? I'm using a Mac and have the app called Android file transfer. Using a Nexus 7.
  16. Andy Johnson-Laird
    10,357
    1,161
    Chris: Can you clarify what you're trying to do, please -- having a Mac and using a Nexus 7 -- are you trying to move the .apk file over to a Nexus 7?
    If so, then the easiest way is using Dropbox on both your Mac and the Nexus 7 and move the .apk file that way.
  17. Chris McKechnie
    Feb 26, 2014
    33
    On my Mac, once the folder is unzipped, it's got a few PDFs, and a .bin firmware file. I've put the .bin file on my Nexus, however, the app isn't showing the update option. Wondering if it's a folder structure issue.
  18. Andy Johnson-Laird
    10,357
    1,161
    The .bin file is not for the Nexus. You need the .apk file for the Nexus. I think you may be trying to install a Mac app on to the Nexus which is running the Android operating system.
    Hope that helps.
  19. Chris McKechnie
    Feb 26, 2014
    33
    Ok, so I put the APK file on the Nexus, but within the freefly app, update firmware is still not an option. Still doing something wrong. Maybe folder structure?
  20. Andy Johnson-Laird
    10,357
    1,161
    All I did was to open up the Dropbox app, it displayed the .apk file, so I double tapped on it and it installs or upgrades.
