Need help with remote recording for Red Scarlet
Discussion in 'Camera Operating' started by Dave King, Jun 21, 2014.
  1. Dave King
    Dave King Well-Known Member
    Dec 24, 2012
    2,712
    311
    The red REMOTE doesn't have a very good range to do this effectively so I bought this unit. http://www.gentles.ltd.uk/gentwire/red.htm based on the suggestions on this board.
    I have it hooked up and wired correctly as the switch on my MX20 is engaging the red light on the gentwire unit however the camera is not recording. The companies directions in regards to the red scarlet are vague at best.
    I have the cable plugged into the sync connector on the red and I thought I had the settings right by looking at the red manual but I must be missing something.
    Here's the settings I have:
    GPIO sync - Pro I/O GPI> PRO I/O
    GPI A High - Record start
    GPI A low - Record Stop
    GPI B high - Record Start
    GPI B low - Record stop
    Keys>Key mapping>advanced
    Key source : Pro I/O GPI
    User Key: Pro I/O GPI high
    Key action: Record start
    Any thoughts?
  2. Dave King
    Dec 24, 2012
    2,712
    311
    I figured it. It was a setting in the brain GPI had to change it to general purposes.
  3. Bo Tornvig
    Bo Tornvig Member
    Oct 14, 2012
    160
    14
    Hi Dave,
    I have tried your settings and it's only working with a normal switch. Do you know how to make it work with a toggle switch?
    Cheers
  4. Dave King
    Dec 24, 2012
    2,712
    311
    Isn't a toggle switch considered a normal 2 way switch on the radio? DO you mean momentary or 3 way?
  5. Bo Tornvig
    Bo Tornvig Member
    Oct 14, 2012
    160
    14
    Hi Dave,
    I tried to make it work with a 2 way switch (the one with the spring) with no luck. But I signed a available 3 way switch for stop/start. But my camera operator would prefer to have it on the (spring) switch..
