My First mods
Discussion in 'MōVI M10' started by J Griffin Ricker, Sep 15, 2013.
  1. J Griffin Ricker
    May 18, 2013
    30
    I modified the RR fingerwheel to fit the right handle. It fits like a glove and sits in the perfect position. Now I can wrangle my own focus! Also mounted the RR motor to one of the height adjustment arms so it counterbalances the motor and eliminates the need for a baseplate and rods. Next I'm going to try to strip the hard rubber cover off my RR motor cable to make it work less like a stick and more like a cable...
    Anyone else brave a mod or two yet?
  2. J Griffin Ricker
    May 18, 2013
    30
    Stripped the hard rubber off the RR motor cable - makes all the difference in the world (obviously). The cable inside is wrapped like braided stainless and looks pretty durable. Hopefully I won't have any ground or interference issues. We shall see....
  3. Wolfgang Armin
    Wolfgang Armin Active Member
    Sep 20, 2012
    291
    25
    That sounds pretty cool, thanks for sharing - do you have an image of your setup (particularely the RR motor mount)? Can´t do any mods yet, need to wait quite a while for my M10 to arrive.
  4. Carey Lee Coffey
    Jul 13, 2013
    194
    16
  5. J Griffin Ricker
    May 18, 2013
    30
  6. J Griffin Ricker
    May 18, 2013
    30
    I also made that baseplate out of a Pico Dolly and RR parts. It's tiny and weighs nearly nothing. Not sure I even need it now though with the motor mount where it is. Probably good to have in a pinch I suppose.
    Stripping that motor cable worked brilliantly. I've done everything I can to cause interference and nothing effects it. Only thing stripping it seems to have done is make it more useful. :)
  7. J Griffin Ricker
    May 18, 2013
    30
  8. Wolfgang Armin
    Sep 20, 2012
    291
    25
    That's brilliant!!!
    J Griffin Ricker likes this.
  9. Carey Lee Coffey
    Jul 13, 2013
    194
    16
    Gorgeous! Hope my MK3 works as well!
  10. Christopher Barrett
    Aug 16, 2013
    47
    Did you mod the thumbwheel or does the clamp happen to fit that tube?
  11. J Griffin Ricker
    May 18, 2013
    30
    Sadly the original thumbwheel mount is about 1/4" too thick/small. Took some careful trimming with a Dremel to make it fit (and you have to cut the rubber hand grips and notch that round carbon plate at the top obviously). That said, totally worth it.
    BTW, if you do this 2 things; be careful not to breathe in any carbon or aluminum dust while Dremeling and don't feel bad about cutting up the rubber grips; they're easy to replace IPO BMX grips that cost about $8.
  12. Carey Lee Coffey
    Jul 13, 2013
    194
    16
    Get the universal thumb wheel . It fits any gauge tube.
  13. J Griffin Ricker
    May 18, 2013
    30
    Cool. I just used what I had. If they make one that'll fit without a hassle that's great.
  14. James Ng
    James Ng New Member
    Sep 5, 2013
    11
    I'm running with a similar setup, but using the universal thumb wheel which attaches nicely to the MOVI.
    Does anyone know where to buy or have made more flexible LEMO cables to replace the Red Rock Micro ones? I'd ideally like something as flexible as the ultra thin HDMI cables.
  15. Chris Durkee
    Chris Durkee Member
    Sep 5, 2013
    45
    does this universal thumb wheel come from redrock or somewhere else?
  16. Carey Lee Coffey
    Jul 13, 2013
    194
    16
    Redrock sells them. Check their website.
  17. Carey Lee Coffey
    Jul 13, 2013
    194
    16
  18. J Griffin Ricker
    May 18, 2013
    30
