MR CONVERSION ADVICE
Discussion in 'MōVI MR' started by Matt Kearney, Oct 14, 2013.
  1. Matt Kearney
    Matt Kearney Member
    Oct 6, 2012
    41
    Hi Guys,
    Think i will answer my own question but just incase anyone had a better idea thought i'd ask!
    Have my scarlet on my m10. With perfect balance on the pan axis there is not enough room on the horizontal carbon tube to fit the rear landing leg behind the vertical tube.
    Obviously if i move that forward so the leg fits im going to be front heavy- i have enough room to move the side arms back to bring the whole load backwards without the camera fouling on the roll bar therefore moving the upright forwards so i can fit the landing leg.
    Sound right??
    All ideas welcome.
    Matt
    Matt can you post a couple of photos of your setup?
  3. Tim Joy
    Tim Joy Active Member
    Aug 2, 2012
    405
    72
    Perhaps a longer tube is in order?
  4. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Hi Matt, you nailed it. You can slide the 2 side arms in a bit or go to a longer tube for the rear leg. Can you post a photo of your setup? I am surprised it will not balanace with the stock tube. Wondering what lens etc you are runnign?
    Thanks!
    Tabb
  5. Chuck Taylor
    Chuck Taylor New Member
    Feb 26, 2013
    28
    Hi Matt, I had the exact same problem as you.
    I grabbed a longer tube off the old gimbal and put it in its place. In my case I was flying my RED Epic with the Canon EF Mount. I had that mount because I liked to use lenses with IS built in pre-Movi. So the lens I was using was the 24-105mm Canon EF lens, which has IS built in. This is obviously more nose heavy than if a prime were used.
  6. Justin John
    Justin John Member
    54
    10
    Has anybody replaced the vertical tube to give more roll room when the Epic is mounted top down ?
  7. Justin John
    Justin John Member
    54
    10
    Here is a quick test from today.
    Kristian C likes this.
  8. Tabb Firchau
    Jun 28, 2012
    911
    472
    Looks great Justin! Loved the lens flares
    Bryan Harvey likes this.
