Movipro and IBIS lenses or cameras
Discussion in 'MōVI Pro' started by Trevor Smith, Sep 4, 2021.
  1. Trevor Smith
    Trevor Smith New Member
    Aug 31, 2021
    Hi,
    I am about to buy my first Movi gimbal ( Movipro) after years of DJI gimbals. Looking forward to hopefully having a more reliable system. I am interested to know if you can use IBIS ( in built image stabilization) lenses ( eg Sony 24-105 F4) or cameras with steady shot ( Sony A7111) with the Movipro? Does IBIS help or hinder the stabilization of the Movipro? I found I definitely needed it with DJI gimbals to help smooth the shots. Thanks in advance!
    Regards
    Trevor
  2. Graham Futerfas
    1,257
    243
    I would test it, because I've seen some wonky footage when the IBIS was turned on while the camera was on a gimbal. IBIS works well if you're holding still, but when you start to walk with it, it can have some odd effects, like wagging from side to side. You shouldn't need IBIS when on the Movi, but again, it's worth testing.
  3. Trevor Smith
    Aug 31, 2021
  4. Trevor Smith
    Aug 31, 2021
    Thanks Graham.
  5. Ben Ellingson
    Ben Ellingson New Member
    Dec 10, 2013
    13
    For hand held or jib work, ou should be fine. However if you're doing camera car or drone work, IBIS cameras should be avoided. Any vibration that makes it to the camera will shake the sensor, causing pretty terrible results. That said; again hand held is fine, though there will be weird flaring induced by the sensor moving around, so I'd turn IBIS off...
