Movi XL + futaba control
Discussion in 'MōVI XL' started by Ariel Velez, Oct 30, 2018.
  1. Ariel Velez
    Ariel Velez New Member
    Jul 14, 2017
    Hi. I would need to know if there is a possibility to connect the movi xl to a futaba command.
    when I use the MXL in my cablecam Dactyl and reach 170 meters away from the controler, the head loses signal then I would like to try with a futaba.
    It usually happens when the show is performed in large stadiums
    Did someone do this before?
    Thank you very much for any info!
  2. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Yes, we use MoviXL with Futaba too.
    You need a cable from Freefly store though.
    Another thing you can do is to add a booster to Movi Controller. Search the forums on this topic, you will find useful info there.
