Movi Wheels powered but not connecting
Discussion in 'MōVI Wheels' started by Paul Begin, Aug 18, 2019.
  1. Paul Begin
    Paul Begin New Member
    Jan 7, 2015
    10
    Hi I’m trying to use Movi Wheels for the first time but not able to connect. Movi Pro and Mimic are both v 2.0. Mimic is connected to wheel with UART to Mimic cable. white LED light comes on and if I press pause on motor it turns blue. On Mimic-Input Setup: Wheels is enabled but below says wheels not connected. Any help would be greatly appreciated. Is there a Beta firmware for Movi Wheels?
  2. Paul Begin
    Jan 7, 2015
    10
    This is photo of what I’m experiencing. Does anyone know what the next step would be to get the wheel to register? FB2127D8-FE23-4A24-8FCD-6409B6B63637.jpeg
  3. Graham Futerfas
    1,258
    243
    Have you contacted Freefly Support? I don't own a set of Movi Wheels, so not sure how to diagnose, but I'm sure they can help you.
  4. Paul Begin
    Jan 7, 2015
    10
    Hi Graham
    Yes I have just waiting for a reply but thought I would try the forum as well. Thanks
  5. sean c mehen
    sean c mehen New Member
    Jan 3, 2017
    there was a batch of mimic to wheels wires that have the red and black wired swapped. wait for them to contact you and double check the wire diagram.
  6. Paul Begin
    Jan 7, 2015
    10
    Yes we were actually able to rewire the cable which worked and Freefly also sent out a replacement.
    sean c mehen likes this.
  7. sean c mehen
    Jan 3, 2017
    great to hear i went thru the same thing a few weeks ago and also got a replacement. that also came wired wrong, oops. all good i was able to do the switch
    Paul Begin likes this.
  8. Kishore
    Kishore New Member
    Aug 14, 2013
    same issue with Movi controller!!
    can some one help me connecting all 3 wheels to my Movi XL?
    I connected all three wheels but unable operate all the wheels... in controller in TX config I enabled mode to: Movi Wheels & connected all three wheels but it show only one wheel... switched all three wheels but it only enables One wheel...
    Movi XL is on 2.0 Beta & Movi Controller is on version 4...
  9. Paul Begin
    Jan 7, 2015
    10
  10. Paul Begin
    Jan 7, 2015
    10
    I would check the cable if it’s wired correctly or even if it’s just not all of the way plugged in.
