Movi pro won't hold axis
Discussion in 'MōVI Pro' started by Brian Alexander, Apr 16, 2017.
Tags:
  1. Brian Alexander
    Brian Alexander New Member
    Apr 16, 2017
    13
    I just got move pro and balanced camera, but it won't hold axis, it floats the way I tilt and pan it. First time with a movi had ronin before.
  2. Graham Futerfas
    1,213
    237
    Hi, did you Auto-Tune it?
  3. Brian Alexander
    Apr 16, 2017
    13
  4. Graham Futerfas
    1,213
    237
    OK. Can you please give more information about the problem? The way you describe it, it sounds normal, but maybe I'm not understanding what's wrong.
    When I have the Movi balanced and tuned, I want it to 'float' the way I pan and tilt, smoothing out the movements. This is the way Majestic Mode works. There are settings in the App (Window, Smoothing, Motor Stiffness) that can affect the response of the Movi, but please offer more details about your problem.
    Can you make a video and post it? That is often helpful.
  5. Brian Alexander
    Apr 16, 2017
    13
    video coming but so basically when I roll the the cage or pan it the axis of the camera rolls instead of floating horizontal and maintaining a horizon
  6. Graham Futerfas
    1,213
    237
    Well that doesn't sound good. Please post a video. What are your Motor Stiffness values after Auto-Tuning?
    Also, in the App, under the General tab, are you in Handheld Mode? If you're in Aerial, that might be the problem.
  7. Brian Alexander
    Apr 16, 2017
    13
    ya its in handheld
  8. Brian Alexander
    Apr 16, 2017
    13
    here u go
  9. Gary Haynes
