Movi Pro Ring Feet
Discussion in 'MōVI Pro' started by Joe Tamel, Jan 18, 2017.
  1. Joe Tamel
    Joe Tamel Member
    Oct 12, 2013
    33
    Hey Gang.. Finally assembling my Movi Pro. Wondering if anyone has issues with the feet on the movi ring a little loose. I've tightened the screws down as much as I can and the feet work, but I can move them around a bit. Like they need to be tightened more. Any clues?
  2. Graham Futerfas
    1,258
    243
    Mine seem very tight. I don't notice any 'play' or slop in them, even if I try to move them with my hands. It is possible to install the feet backwards, so your Movi should have a little angle\lean toward the feet. Not much, just a few degrees, but if they're backwards the Movi will sit too upright on them and can fall over if you put a weighted camera on them.
  3. Ryan Forte
    Ryan Forte Member
    Oct 5, 2015
    69
    I called Quadrocopter after I started putting the ring together for the same reason. They told me a little wiggle in the feet are part of the design. If you aren't getting any play in your ring I'm starting to question their answer they gave me!
  4. Ben Platts
    Ben Platts Active Member
    Jan 24, 2013
    186
    25
    Mine were loose too. I just put a strip of tape under them before I tightened them and they are tight now.
    Dale McCready and Runar Blekken like this.
  5. Bryan Edmonds
    Jul 3, 2014
    253
    126
    A little bit of looseness is by design. It helps both feet touch the ground, if the surface isn't even.
    There is some slight variance in the diameter of the carbon tube, so it won't be exactly the same on every unit. But it should be close, and the feet won't fall off if they don't clamp down 100% to the ring.
    Chris Ray likes this.
  6. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Hi. Just put mine together and they aren't loose on the tube but they have a bit wiggle when on the ground. One is slightly higher then the other. Is that normal?
    Also they sit at 9 degrees lean forward not 4 degrees as in the manual. Is that ok too?
  7. Mike Vickers
    Mike Vickers New Member
    Oct 18, 2013
    25
    I just got my Movi Pro in last week and it's the same with mine too. The feet aren't loose at all but one foot is slightly higher than the other causing it to wiggle on the ground. I took the feet off and swapped them around and it's the same thing.
  8. Alasdair McBroom
    Alasdair McBroom New Member
    Jun 10, 2014
    19
    I have the same problem with the feet being uneven when sitting on the ground. They're not loose at all but there is a very noticeable difference in the height from the ground. Maybe 3-4mm.
  9. Benjamin Granet
    Aug 31, 2015
    38
    10
    I don't have any issues with the feet but I have another problem with my Movi Pro Ring. Does any of you hear cracking noise from time to time?
    The ring is brand new so I'm curious if it's a design or manufacturing problem? I'm worried to have comments from sound guy as I do a lot of fiction.
  10. Jason Comparetto
    Sep 23, 2013
    269
    38
    I'm not sure if its possible to reverse the feet but if so, perhaps there may be a little bit of improvement, simply because as they said earlier--there may be a bit of difference in the tolerance of the carbon fiber. Just enough to create an asymmetrical level. If that doesn't work, we could laser-cut a batch of plastic shims for the feet, which will adjust the height of the shorter leg. If someone needs these, just contact us at jason@JasonCases.com
    Graham Futerfas likes this.
  11. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Nope tried that right away and equally rocky.
  12. Azzie Scott
    Azzie Scott Member
    Jun 29, 2017
    55
    Yup my feet don't equally sit flush, one is like a milliliter or two off and it has a slight rock or wobble.
  13. Andy Johnson-Laird
    I recall an earlier posting from one of the FF support mages and they said that this was deliberate so that it could adapt better to sitting on an uneven surface.
  14. Graham Futerfas
    1,258
    243
    good memory, Andy -- that post is from Bryan 8 posts above on this page. :)
    I think my Ring's feet loosened up a bit over time. I swear they were stiffer than they are now.
  15. Andy Johnson-Laird
    See! See! I knew I'd seen it somewhere!
