Movi Pro Ring doesn’t sit flat (uneven feet)
Discussion in 'MōVI Pro' started by Chris Tawney, Jul 24, 2018.
  1. Chris Tawney
    Chris Tawney New Member
    May 14, 2018
    I just purchased my Movi Pro and when I installed the feet they are uneven enough to see under the back of one of the feet on a flat surface. I tried installing some backup feet I had from previous rentals and that didn’t solve the problem. My question for those with more experience is whether the Movi Pro Ring rocking because the feet are uneven is an actual problem? And has anyone else found a fix for this?
    10,246
    1,135
  3. Chris Tawney
    May 14, 2018
    10,246
    1,135
    I'm afraid I don't know the answer to that Chris -- I just know that all the Movi Pro I've met seem to have slightly loose feet and the unit rocks a small amount. Can you post an image of the issue -- it sounds like the amount of unevenness on your unit is not normal...
    Cheers
  5. Chris Tawney
    May 14, 2018
    They're actually super tight which is nice, but uneven. It's also true that I've always been a bit overcautious about my gear and a little too worried about every detail.
    10,246
    1,135
    Hmm. That's pretty much how the feet on my MP are.....but, if you're concerned, I'd suggest you open up a ticket by sending an email to Freefly Support (support@freeflysystems.com) and double check with them -- you can cite to this thread so you don't have to write it all out again -- and they can see the image.
  7. Gerfried Guggi
    Gerfried Guggi New Member
    May 15, 2017
    18
    I've asked this myself a couple of times, but has never bothered me while working.
  8. Chris Tawney
    May 14, 2018
    I actually received a response from FreeFly support and they said it was intentional like Andy stated above. It's strange, but so far hasn't caused even the slightest problem.
