Movi Pro main rods to gage not aligned
Discussion in 'MōVI Pro' started by Kevin Schmid, Jun 30, 2017.
  1. Kevin Schmid
    Kevin Schmid New Member
    Apr 10, 2013
    25
    Hello,
    We have had issues getting our rig tuned, with constant vibration. In different setups. We have notices that the main two rods going to the cage are not aligned correct. Must see the pics. Without sending the unit back as now time for that what will be right solution to get it fixed without creating new issues?
    THX for a feedback.
    Peter
    P.s. we have opened at ticket with Freefly, but not heard back from them.
  2. Graham Futerfas
    1,261
    245
    Can you look in the app and see what motor(s) is vibrating? There's a red indicator in the Tuning section that can tell you where the noise is. Try reducing the stiffness, hold strengths or increasing the filter on the motor that's vibrating.
  3. Kevin Schmid
    Apr 10, 2013
    25
    it is the pan, but my point is that the rods are not 90° to the pan motor, see the photo and the angle and you will see it messured agains a
    protractor.
  4. Ben Platts
    Ben Platts Active Member
    Jan 24, 2013
    186
    25
    I have always found that my Pro is naturally out of balance on the pan axis and tried to work out where the imbalance was. Perhaps this is it. I can only balance the pan with one battery on due to how out of balance it naturally is. Very interesting to see measurements showing that the rods on yours are out of shape.
    Deniz Ertan likes this.
  5. Jason Comparetto
    Sep 23, 2013
    269
    38
    I'm not sure if that would create a problem. But if it does, Have you tried setting the rods into the correct placement? it seems like it could be done by loosening the screws and re-tightening them. You'll need a better way to gauge the correct angle. You may want to use a carpenter's square or something similar
  6. Kevin Schmid
    Apr 10, 2013
    25
    Yes Jason, I was wondering about loosening those screws to. Just wanted to ask to make sure that we do not change anything for the worse. I do have the right tools to check on the correction to.
    So if anyone has seen the same problem it would be assuring to me that we are on the right track.
  7. Andy Johnson-Laird
    I'd open up a ticket with Freefly Support (support@freeflysystems.com) before you start doinking (technical term) with the main support arms, Kevin. If they tell you to try that, all well and good, but otherwise you may be just digging yourself further into a hole.
  8. Kevin Schmid
    Apr 10, 2013
    25
    Hi Andy,
    We have opened two tickets with the support team and no response since over a week. So thats why we are in the forum now.
    Hope to get this solved soon too. But thanks for your advice.
    Regards Kevin
  9. Andy Johnson-Laird
    Did you get a confirmatory email that your message had been received, Kevin? FF's system sends that back automatically along with an explanation of the likely response times...did you see such a message?
  10. Kevin Schmid
    Apr 10, 2013
    25
    Yep, got confirmation e-mai stating 3-4 business days, ticket was opened last week. so still waiting. But thx anyhow.
  11. Andy Johnson-Laird
    OK, well at least the ticketing system and email is functioning. I suspect FF's closed on Tuesday for the July 4 holiday -- not sure about Monday.
    But, in the hope that some of my ideas might help: Have you managed to balance the MP with the camera on it OK? I realize the main support booms look misaligned, but if everything balances perfectly I'm not sure how much that might matter. The Gimbal Control Unit just "sees" a mass -- it doesn't know that the vertical booms are out of alignment unless it's causing an out-of-balance condition (which it does "see.")
    I also presume that you've done an autotune. Out of curiosity, what Autotune Percentage did you use?
    Finally, can you check that nothing on the MP is loose or can waggle -- any mass on the MP that can do so acts like a pendulum and will make for a crappy autotune.
    Graham Futerfas likes this.
  12. Kevin Schmid
    Apr 10, 2013
    25
    Hi Andy,
    We can confirm that we did the standard procedures as of manuals. Used M5 for 2 years. We did have problems with balancing the pan, logically. it was never 100 %! I do not think that the control unit will get this misaligned rod corect. Auto Tune at 60-70 %. Setup is GH5 Video Downlink, really simple. Will see what FreeFly has to say.
    Kevin
  13. Andy Johnson-Laird
    Sounds like you've done your homework, Kevin. I'm not quite sure what else to suggest beyond, as you say, waiting for FF. Please post again once you hear from them so other forum members can benefit from what you find.
  14. Deniz Ertan
    Deniz Ertan New Member
    Jun 19, 2017
    Mee too.
  15. Kevin Schmid
    Apr 10, 2013
    25
    So we have finally received a solution from tech support. In our case it is a specific issue with the carbon spine. If anyone might have a similar problem or issue, I think it is best to contact tech support and open a ticket. This, not to get other people having balancing issues on the MoVI Pro confused. Hope that helps.
    Kevin
  16. Ben Platts
    Jan 24, 2013
    186
    25
    I've had a ticket open with FF support but they haven't responded in a month! Glad to hear they do still exist!
  17. Andy Johnson-Laird
    Kevin: Could you elaborate a bit so that other forum users can recognize the "specific issue" should it happen to them, please?
  18. Kevin Schmid
    Apr 10, 2013
    25
    It seems that they are getting more support tickets as usually. We waited over 2 weeks to get movement into the case.
    Kevin
  19. Kevin Schmid
    Apr 10, 2013
    25
    Hi Andy,
    So according to support it is possible to loosen the necessary bolts to allow the carbon spine tubes to be moved very very carefully into the correct position, so that the are aligned correct to pan motor assembly. But if not done right it can cause new other problems. We moved along as support told us an will do some testings next days. If it did not work, we will be back posting infos and question.
    Kevin
    #19 Kevin Schmid, Jul 18, 2017
  20. Andy Johnson-Laird
    Thanks, Kevin. What you wrote makes good sense.
