With any Beta software, don't do it during a job or immediately before where you have no time to revert. That said, you can revert back if you want. I've been using 1.4 since it came out (a month ago?), and it's been reliable.
So I just installed the 1.4 beta and as far as operation goes so far so good, but I have two main issues with the UI. on the Movi Pro screen I can't change the auto tune percentage, and it won't even show what the current setting is. It just shows "%" with no number. I can change it via the app, but not on the movi. secondly in the iOS app When I go to configurations and go to the Majestic screen, I can't go back to the previous screen, the back navigation arrow disappears. No matter where to tap, you can't navigate back to the previous screen. Thirdly in the monitor screen the "Status,Charts,Updates" text is chopped off and barley visible. Lastly, I love the added Majestic Roll feature, but are you able to roll 360? or at least close to it. I thought I read somewhere that was possible.
I just looked at my Movi running 1.4 and don't see any of these issues. Everything works: auto tune percentage on the Movi screen, navigation in the app from Majestic settings, and I don't see anything cut off on the app screen.
I just rebooted my Movi and the Auto tune configuration access and percentage has returned, I deleted and reinstalled my iOS app still has the issues I described.As you can see theres no way back to the previous menu and on the second image you see the text is cut off. Not sure if it matters but I'm on a iPhoneX
I think Bryan Edmonds mentioned somewhere that iPhone X was a different screen size to program Apps for and could cause issues.
The released version of the Movi app works fine on my iPhoneX, @Bryan Edmonds if you can chime in, will there be a beta update to this IPhoneX issues. And is there an eta on the the release 1.4v ?
Using the MP with the beta 1.4 app on an iPhone X using iOS 11.2.2, I've noticed: Some of the caption text at the top of the screen is clipped (the lower part of the letters do not display properly). If you tap on About, the app crashes. That was just "first impressions" -- I've not tested it thoroughly yet (it's on my bucket list). Cheers Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Also I noticed there isn't any way to enable Majestic roll on the Movi Pro screen, on in the app, I hope this will be added in the release version. @Bryan Edmonds
Is anyone else having issue with roll on the 1.4 beta? I have mine set to Ch1 (tried others as well) but I am not able to control roll with my 14sg. The app registers that it is receiving input but nothing happens on the gimbal. I am in airborne mode. I am going to try a few tests before I revert to see if I can find a fix. Worked fine on the last stable build so I am going to drop back down to that for now.
Just in case someone see's Mike's post here, he posted on another thread that he did a reset to Factory Defaults and all was well. Cheers Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
