Hi All, Here is a little power breakout that I have built that works with our MoVI top plates. The power breakout has four 0B.302 Lemo plugs in it, which you can feed power into with a D-TAP to 2-Pin LEMO Cable. Or you can power it as we do from the LBUS port on the Alexa Mini. We use this to minimise the clutter on the camera, and power our accessories. When the camera is in the MoVI Pro we use this to power the Terradek Bolt, and RT Motion. When we switch out to handheld, we use it to power our Small HD 502 monitor as well. Cheers Chris
