Hello, Does anyone have information on when this will be available or if there is a kit from freefly that will be available if you order the M5? Thanks! Ryan
I contacted Quadrocopter recently, and there hasn't been any information released on this yet. I'm hoping that they do make the M5 multirotor friendly. I'd be kind of surprised if they didn't. We'll see what gets released in March. Fingers crossed. -Ben
One has to hope that the M(R)5 is more aimed at aerial work. Seems like the majority of folks using the M10 are using it on the ground, at least from the chatter here.
Yep, it's the reason I'm standing in line for the M5... Don't see a reason why the current legs wont work but I guess we'll see.
There will be an MR kit available for M5. It will be priced the same as the current MR kit and will include everything you need to turn the M5 into a multi rotor version. Tabb
HI Janne, The landing gear assembly is available as an optional accessory for the M5. Greetings, Adam
We (Rule Boston Camera) have pricing on the multirotor kit for the M5. its $300. sutton at rule dot com to order
Daisuke-san: I see no reason why the M5 would not fit on the Cinestar 6. The MR kit has a standard four-point attachment plate as far as I can tell. Andy.
Daisuke-san: I was wrong. The Cinestar 6 uses a three-pointed mounting plate. You will need to special order that when you order the M5 MR conversion kit. Thanks Andy.
