Movi m5 signal lost
Discussion in 'MōVI M5' started by kjetil tønnesen, Aug 14, 2014.
  1. kjetil tønnesen
    Aug 16, 2012
    417
    23
    Hello
    i am flying with m5 and when i am 80-100 meter away from me ,i lose the signal to my spektrum radio and the tilts is hikking,how can i get this better,a bit disapointed about this this:-((
    i have try moving the satelite from the movi and out on the landingleg but that didn´t help
    so what to do
  2. Juha Knaapi
    Juha Knaapi New Member
    Jul 30, 2013
    15
    I had this same problem with M5 and I didn't find any real solution, crude way to deal with this is switch to Futaba.
    Another topic with same problem here.
  3. Andy Johnson-Laird
    10,354
    1,160
    Kjetil: In Europe, transmitters are required to have a reduced radiated power. You don't mention whether you purchased the Spektrum transmitter in Europe, or what model of transmitter you are using. But in Europe, I believe you are limited to a radiated power of 100 milliwatts (as opposed to the 300 milliwatts for the US).
    Could this be the issue?
  4. kjetil tønnesen
    Aug 16, 2012
    417
    23
    ok i have tried everthing about the spektrum reciver and nothing fix the problem theat the signal is lost,so i have get me a futaba radio,
    i wounder how to connect it and bind it to the movi? is there some video of how to do it ?
  5. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    839
    67
    Just need to connect s-bus, unscrew the four screws on the side remove the spektrum cable and plug in the s-bus connection. DONE!!
  6. Zaid Al-Obaidi
    Zaid Al-Obaidi New Member
    Jun 15, 2014
    19
    But you shouldn't have to do this, I have asked the support team about this issue, but unfortunately no real solution amognst other issues we are having.
    Why on earth can't we have a full range Spectrum RX on the MOVi5 I don't know , how are people expecting to trigger their shutters manually, surly its in the design spec !
    The whole RC world should not have to conform to this brand Or the other, its a personal choice based on experience, I know guys will not touch spectrum with a barge pole and vice versa. I Know Futaba is good then WHY did Freefly not sell Futaba hand sets with the Movi as a package ???
  7. kjetil tønnesen
    Aug 16, 2012
    417
    23
    I am agree with you
  8. kjetil tønnesen
    Aug 16, 2012
    417
    23
    Thanks for letting me knowno setup in the firmware?
  9. Jason Smoker
    Oct 23, 2012
    839
    67
  10. Paul Garlick
    Paul Garlick New Member
    Oct 8, 2014
    A question for kjetil, have you changed to Futaba? Did it solve the signal loss problems?
    I'm having exactly the same problem with my movi5 and my supplier can't figure it out.
    I need to know if changing from spektrum to futaba is the way forward.
    Surely Freefly should sort this problem for us, if the spektrum isn't good enough to do the job.
  11. kjetil tønnesen
    Aug 16, 2012
    417
    23
    hello
    i have change to futaba and the problem was solved:)
