Movi M5 MR weight?
Discussion in 'MōVI M5' started by Peter Gøthche, Nov 10, 2013.
  1. Peter Gøthche
    Aug 21, 2012
    136
    14
    Any one know the weight on the m5 mr?
    Peter nothing has been finalized yet.
  3. vijay bhasker
    vijay bhasker New Member
    Dec 5, 2013
    M5 is compaitable with sony fs 700 with 16mm lens 770 batterie
  4. Gary Haynes
    Vijay I think you meant to say the M10?
  5. Just a reminder that some of those larger Sony NP-f series batteries stick out beyond the battery bay on a lot of cameras.
  6. vijay bhasker
    Dec 5, 2013
    I mean M5 Load capacity?
  7. The MoVI M10 has a weight limit of 12 Lbs (5.4 kg), the MoVI M5 has a weight limit of 5 Lbs (2.2 kg). Factor in the weight of your camera/lens combination and if you decide to add additional equipment. Anything mounted on the top cross bar does not affect the weight limit on the gimbal.
  8. Drew Kachurak
    Drew Kachurak Member
    Aug 9, 2013
    188
    23
    Is the MR conversion kit for the M10 the same for the M5?
  9. We do not have any MR kit linked to the M5. It may be the exact same kit, it may be a slightly different kit. Closer to the release date of the M5 we will announce the availability of other support products for the M5. Until then please Join our mailing list and we will keep you updated with all information of future products.
    Mailing list link here. http://freeflycinema.us6.list-manage.com/subscribe?u=1bd4ba82ae033588b6963f595&id=10333383e5
    Thanks, Chris
  10. vijay bhasker
    Dec 5, 2013
    Sony Fs 700
    Body only: 3.25 lb (1.47 kg)
    sony 16mm 2.8 lens weight
    2.47 oz (70 g)
    sony NP-F970 Batterie weight
    12.3 oz (350 g)
    Total 1890g so under 2.2 kg . this
    configuration will work for Movi M5?
  11. Steve Maller
    According to what Chris said above, yes.
  12. Gary Haynes
    Vijay others have been reporting challenges balancing the FS700 on the MōVI. Until the final specs are released and reading Chris's post #9 there really isn't a definitive answer.
  13. Steve, regarding post #9, I was answering Drew's #8 question about the M5 having the MR option when the M5 starts shipping. My answer had nothing to do with weight limit or camera compatibility. Weight limit is not the only factor. One of the factors that contribute to the MoVI M5 having a smaller weight limit is because, it's smaller. Sure, there are cameras that fall within the 5lbs weight limit but size and shape are also an obvious factor.
    Thanks, Chris
