The MoVI M15 has a weight limit of 15 lb (6.8 kg) The MoVI M10 has a weight limit of 12 Lb (5.4 kg), the MoVI M5 has a weight limit of 5 Lb (2.2 kg). Factor in the weight of your camera/lens combination and if you decide to add additional equipment. Anything mounted on the top cross bar does not affect the weight limit on the gimbal. Size and shape of your camera package is also a factor, not just weight. Please see the attached camera chart.
Hi Chris, I see the chart, but I had seen some beta testers fit the Blackmagic URSA Mini to an M10. Can you confirm this is a no go from the testing you guys do? We are about to receive this camera in a few days and having it work with our M10 is critical. Thanks!
C300 is too heavy for a M5. C100 with L glass can fit, unless the lens is too long and front heavy. There will always be people trying what is not recommended...
