MOVI M15 Won't Turn On...
Discussion in 'MōVI M15' started by Chris Bourke, Mar 2, 2016.
  1. Chris Bourke
    Chris Bourke New Member
    Nov 21, 2014
    Hey folks,
    I'm in a bit of a panic at the moment.
    I've got a shoot in 3 hours and I just calibrated everything and went to turn on the M15 and it won't boot up...no LED's, no motor noises, no anything at all. It's completely dead. Both batteries are fully charged and had not been depleted on any previous shoots. I tried to reboot with the jumper and had no luck, the movi still showed no power whatsoever.
    Any ideas guys? The controller is not on or anything. I have no idea what the issue could be.
    Thanks in advance.
    Best,
    Chris
  2. Adam Brennan
    Adam Brennan Member
    Dec 29, 2013
    234
    14
    I would double check all connectors to make sure they are seated correctly.
  3. Brett Harrison
    Brett Harrison Active Member
    Apr 7, 2013
    299
    40
    Hey Chris, I'm not doing anything in particular ATM, if you need help on the phone PM me if you need help locating and checking all the connectors and general trouble shooting (since Freefly HQ are sleeping).
  4. Graham Futerfas
    1,236
    240
    Hey Chris, did you get it sorted out?
  5. Nicolas Quintela
    Nicolas Quintela New Member
    Nov 16, 2016
    I am having exactly the same problem with my M15 right now!
  6. Brett Harrison
    Apr 7, 2013
    299
    40
    The 3 flashing lights of doom is a common symptom to many different causes - best to shoot an email to support@freeflysystems.com to get you sorted out.
