Movi M15 shaking
Discussion in 'MōVI MR' started by Brice Tholozan, Oct 5, 2015.
  1. Brice Tholozan
    Brice Tholozan New Member
    Sep 6, 2013
    29
    Hi, I already send a mail at freefly but I think you can help me :D
    We have a M15 on a X8 drone (as you can see in the video).
    In the second video you will be able to see some shaking.
    When we stay steady, it won't vibrate, but as soon as we move (or when it's windy) it become shaky.
    Do you think that with retractable landing gear we won't have theses vibrations ?
    Do you think we should put different setting for the MOVI when it's windy and when it's not ?
    The Gyro filter was set on 5, should we change it ?
    Our firmware 4.02,
    Setting :
    Pan 215
    Roll 76
    Tilt 58
    We tried with
    195
    66
    48
    but it was worst...
    we tried also with different gain of the DJI A2, Currently 100% but sometime less 60 or 70 and its the same.
    Gryphon X8 1000, Herkules III, Tmotor u7 490kv, tmotor 18", blue damper
    we have also movi M10 and its the same
    thanks for your sharing
  3. Gary Haynes
    If those are the Blue Isolator bands from Freefly you may want to try the harder Black o-rings. If the dampers are bottoming out due to weight then it would translate any frame vibrations to the MoVI.
    Another thought is that the extensions attached to the gimbal plate might also be adding to any issues you are having. Anyway of removing those? They look like they are flexible rubber standoffs. Some folks have found that by having essentially a double setup of vibration mounts they tend to fight each other.
  4. Brice Tholozan
    Sep 6, 2013
    29
    Ok I'm gonna try, I'll let you know
  5. Brice Tholozan
    Sep 6, 2013
    29
    Hi,
    I change gyro : 3(before5) outputGyro : 4 (before 5)
    Pan : 250
    Roll :85
    Tilt : 60
    Caméra 2.8kg
    Movi 15 + Caméra + Connex + batterie = 5.5kg
    I try many different seeting, and all the time, when I fly with no wind its kind of good, but when there are some wind... its shaking or not good..
    thanks
  6. Gary Haynes
    Julian can you call out some of the time points in the video when you don't think it is doing well?
  7. Brice Tholozan
    Sep 6, 2013
    29
    Somebody can show me a vidéo that no vibration with little bit wind or focal like 35mm?
    for my problem I have only 3kilos in the gimbal, do you think that I have to put more for better result ?
