Movi M15 Ninja Star and Toad
Discussion in 'MōVI M15' started by David Cox, Apr 6, 2016.
  1. David Cox
    David Cox New Member
    Nov 22, 2013
    Hi,
    I want to connect my M15 to a jib via a Ninja Star. There doesn't appear to be enough clearance of the battery cages if I connect to the female Toad, how do I get around this? The Male Toad I have is attached to the crossbeam
  2. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
    Hi David, i don´t think i actually understand your problem. Are you planning to use the Ninja Star instead of the cross beam? Then you will need another male Toad and it works… I have Toads on all my gear and never run into a problem here?
    Best,
    Wolf
  3. David Cox
    Nov 22, 2013
    Hi Wolf,
    Yes, the Ninja Star will be used instead of the crossbeam to connect to a jib. I was wondering if I could connect without having to purchase another Male Toad. It would seem not.
  4. Wolf Schiebel
    Aug 15, 2012
    254
    67
    Hi, nope, you would have to fabricate an adapter/spacer then. And would loose the quick-change capability…
    Best,
    Wolf
  5. David Cox
    Nov 22, 2013
    Hi Wolf,
    Thanks for the input, off to buy another Toad :)
    Kind Regards
    Dave
  6. Adolfo Cantu-Villarreal
    Oct 8, 2013
    78
    David,
    Having that extra male toad + the ninja star will give you lots of options for mounting. Here's a setup we used for timelapse, but we have used a similar setup on jibs (upside down).
