MOVI M10 on a Aircraft
Discussion in 'MōVI M10' started by Jair Guillen, Apr 22, 2014.
  1. Jair Guillen
    Jair Guillen Member
    Nov 1, 2013
    36
    Hi guys, for a proyect here in Peru. We want to mount our MOVI M10 in this little aircraft:
    We want to make some outstanding aerial footage, our idea is to mount the M10 with a DSLR, but i don´t know if the M10 could ride out of this "walk".
    If we put the M10 outside of the plane, anydoby know if the rig could work well with strong winds? Anydoby can test the M10 in a similar situation?
    We don´t want to damage our gymballs, any advice we would appreciate.
    Regards!
    Jair.
  2. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    I've handheld my M10 out of a dragonfly aircraft, which has no canopy. We flew only about 100km/h, the batteries drained after about 40 minutes as they are working really hard, but the results were great. If you are hard mounting the MoVI, I would recommend some sort of suspension system, as turbulence will need to be dampened..
  3. Jair Guillen
    Jair Guillen Member
    Nov 1, 2013
    36
    Thank you for sharing your experience Cam, we are looking for make a very strong suspension system or otherwise use the MOVI handheld. We think also that the suspension system you talk about is a requirement.
    Regards.
