Hello, Using Firmware v3.0.1 with an M15 (firmware v5.0.2) and app version 2.1.1, I get jittery pans and tilts. Sometimes I start the pan, nothing happens for a split second then the pan or tilt will speed up and try to "catch up" where it use to me. I've tried changing the 'expo' and 'smoothing' settings for pan and tilt and it doesn't seem to change anything. Any thoughts on what the issue could be? Thanks
Kurt: When you're seeing this problem, can you use the Menu Select on the MoVI Controller to get into the MoVI Monitor screen. When you're there do you see "jitters" on the Tilt/Roll/Pan axes or just on the Tilt/Roll/Pan Motors, or both?? Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
