Mounting the Amimon Connex
Discussion in 'ALTA' started by Dylan Glockler, Oct 26, 2015.
  1. Dylan Glockler
    Jun 14, 2013
    110
    23
    Just received the Amimon Connex and wondering if anyone has any tips for mounting - in particular the antennas. I'm running an m5 on the Alta.
    Read through the discussion on powering the unit but if anyone has already done some R&D and has suggestions on mounting - might save some of us some hassle.
  2. Ricardo Perret
    Oct 22, 2015
    46
  3. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    I fitted the tx in a similar place to Ricardo but I extended the antenna away from roll arms. I found I had much better performance if you keep the antenna 5cm away from any carbon or metal.
  4. Dylan Glockler
    Jun 14, 2013
    110
    23
    Nice! Thanks for all the pictures Ricardo. Did you make the diversion cable? I thought I remembered seeing it in the freefly store but I don't see it now. Nice, clean cable management.
  5. MIke Magee
    MIke Magee Active Member
    422
    103
    Pete, could you please send a pic of your setup?
    tx,m
  6. Ricardo Perret
    Oct 22, 2015
    46
    Hy Dylan, yes, i made the diversion cable.. its just an Y Cable...
  7. Dave King
    Dave King Well-Known Member
    Dec 24, 2012
    2,711
    311
    Any pics?
  8. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Not very good ones I'm afraid but maybe you can zoom in...
    Ruben Moreno and MIke Magee like this.
  9. Dave King
    Dec 24, 2012
    2,711
    311
    Thanks, Here's I mounted mine last night. I wanted to have them as low as possible. I have only tested it on the ground so far. I just need to zip tie the wires to the plastic tabs for strain relief.
  10. Chris Jordan
    Chris Jordan Member
    Dec 4, 2013
    118
    16
    Good on ya, looks great! Fair warning, the mesh cable sleeve will pull and wear out the connector quickly on the ends and the movi goes in it's roll motion. Find a way to lock the ends down to something rigid, or ALL the flex will be there on the ends and the cable or connector will fail. :)
  11. Dylan Glockler
    Jun 14, 2013
    110
    23
    Question for you Ricardo - did you screw the Connex antenna right into the end cap on the MOVI as it appears? Do you generally just leave it? How about packing it up (do you use the MOVI pelican?)
  12. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    Has anyone found a good antenna conversion coupler? MMCX to SMA? I got a couple from a place called element14, however the coupler didn't sit snugly in the housing and easily came loose.
    I'd ideally like to be able to swap the connex to a handheld camera or between my M5 or M15 for quick turnovers
  13. Dylan Glockler
    Jun 14, 2013
    110
    23
    Is your plan to get a second antenna and just move the transmitter? It seems the antennas will have to come off anyhow to pack up in the case. Velcro might be ok for ground work - thinking of permanently attaching a rosetta to the end cap where it looks like Ricardo attached his permanently by screwing into that end-cap. If I can find the a matching rosetta that has a way to mount.
  14. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    Dual lock for attaching the connex unit is fine for both ground and air work, strong stuff. Easily snap off the connex when packing down if required. SMA antenna's are quick to screw off, so would be easier then using a set of pliers each time to remove the existing antennas. I'd imagine range might be diminished, would need to do some testing.
  15. Dave King
    Dec 24, 2012
    2,711
    311
    I flew the Connex system a couple days the past 2 days and the results were excellent. I was able to go 450 meters before I lost the picture. There was no noise in the system and no pixilization until the edge of the signal strength when it went out completely. I had a couple issues with getting the 2nd receiver to pair with the transmitter. I had to update to 2.1 firmware before it would allow it to pair. My FPV system is on the 5.8 Iftron system and I was thinking about changing it to the 1.2 system I just took off my MOVI. This way there would no possible interference of the two systems.
  16. Jose Luis Ocejo
    Jose Luis Ocejo Active Member
    Sep 20, 2012
    581
    44
    I guess at the Connex price range and performance I cant complain much, but Connex could have design better mounting options for the transmitter and the antennas definitely the cable antennas have to be protected by sleeving them in mesh tubing
  17. Dylan Glockler
    Jun 14, 2013
    110
    23
    It's nice that it comes with a light-weight micro-to-mini HDMI with a little screw to attach at the Connex transmitter side but of course the micro side is a right angle and the Sony a7s port-saver is designed such that the two aren't compatible. If only the right angle was the other right. To add to it, finding another light-weight, adequate length micro-to-mini is proving difficult.
    For anyone looking into a mesh sleeve and wondering which size is appropriate, I found this worked well from Amazon for $11 for 25 feet: Techflex PTN0.25BK25 Flexo PET General Purpose 1/4-inch Braided Cable Sleeve, Black - 25 Foot
  18. Mateusz Hajdziony
    Jul 10, 2013
    80
    I am using HyperThin HDMI cables - they are really flexible and of good quality, but are only available in 80cm lengths. I haven't found any other HDMI cables that are as flexible. Maybe we could ask HyperThin if they could make a batch of shorter cables for us? http://www.hypershop.com/HyperThin/Worlds-Thinnest-Most-Compact-Flexible-HDMI-Cable/
  19. Dylan Glockler
    Jun 14, 2013
    110
    23
    Nice and thin but I'm not seeing a micro to mini on their site, which is what I need to go from the Sony a7s to Connex.
  20. Mark Hoffman
    Mark Hoffman Active Member
    Jul 13, 2014
    130
    25
