Mounting Shure MV88 microphone to Movi Hoodie
Discussion in 'Movi Technical' started by Randy Elias, Oct 23, 2019.
  1. Randy Elias
    Randy Elias New Member
    Oct 23, 2019
    Hi All,
    My first post ...
    Has anyone come across a 1/4" mount clamp accessory that can hold the Shure MV88 Microphone firmly in place on the MCR?
    I will be using moment lenses on my iPhone 11 Pro, so I'll need to use counter weights to balance the phone on my Movi. Thus, I'll need to place the microphone somewhere else (even though it attaches to the iPhone via the lightning port).
    Any ideas?
    Thanks,
    Randy
  2. Rorick Edge
    Rorick Edge Active Member
    May 11, 2018
    452
    81
    If you do a search, I think there is at least one post that may be relevant.
    I assume you know that using the 13mm lens with the MCR is a significant problem. If not, there are discussions about the issue in recent threads.
    #2 Rorick Edge, Oct 23, 2019
    Randy Elias likes this.
  3. Randy Elias
    Oct 23, 2019
    Thanks @Rorick Edge.
    Yeah - I read up on the issues with the 13mm lens. Not sure how often I'll use that lens for doing videos.
    As a follow-up to my question, I"m thinking of making my own 1/4" mount accessory with a 3D printer a friend of mine owns.
    Thanks,
    Randy
    Rorick Edge likes this.
  4. Stephen Hart
    Stephen Hart Active Member
    Apr 24, 2019
    109
    44
    Cross posting from this thread:
    https://forum.freeflysystems.com/in...-recording-to-lighting-jack.12384/#post-88351
    "I made a DIY cold shoe mount for the MV88, mostly as an exercise in tinkering."
    https://eugraph.com/misc/mv88mount.html
    Another solution is the Shure VP83F Shotgun, which can record independently, but is only mono.
  5. Randy Elias
    Oct 23, 2019
  6. Stephen Hart
    Apr 24, 2019
    109
    44
    The idea could easily be improved, and adapted to other materials.
