Mounting monitor to transmitter
Discussion in 'MōVI M10' started by Brendan Isaac, Sep 18, 2013.
  1. Brendan Isaac
    Brendan Isaac New Member
    Jul 12, 2013
    24
    Hey Guys - how are you mounting your monitor to your transmitter?
    Tabb could we get some pictures and designs of your body brace/monitor mount set up please?
    cheers guys
    happy movi'ing!
  2. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
  3. Brendan Isaac
    Jul 12, 2013
    24
    Amazing that beats the quote i just got to get a carbon fibre mold made haha :)
    Thanks Brad!
  4. Gary Haynes
    Available in the US at Esprit Model espritmodel.com
  5. Nick Pujic
    Nick Pujic New Member
    Oct 6, 2013
    15
    Thanks Mike! That was very helpful!
  6. Kevin Winkler
    Kevin Winkler New Member
    Sep 9, 2013
    I ordered the entire kit with FPV Station For SE TX_Tray V1 and just got it and the movi today.
    I also got a ac-7 small hd display but it wont mount to the FPV plate ........any suggestions. Not one of the screw holes match. Im thinking im going to have to make a bracket myself.
  7. Mike Duval
    Mike Duval Member
    Apr 24, 2013
    66
    18
    Here is what our FPV rig ended up being all assembled with the Secraft transmitter parts as listed above.
    Small HD AC7 OLED with the universal battery adapter plate. We used the black thumb screws that normally attach the LP-E6 style plate to the monitor. Its a tight fit through the Secraft FPV monitor frame but it works. You can line up the two end screw holes to fit the central slots and screw the monitor directly to the tray.
    For power these are the items we ended up settling on:
    Ikan Battery plate adapter for Sony L series batteries: http://www.bhphotovideo.com/c/product/753490-REG/Ikan_BP2T_S_BP2T_S_Sony_Battery_Plate.html We used this to power the Small HD monitor as they share the same barrel style connector size as the AC7 (2.1mm center positive plug).
    To power the Teradek Bolt Pro 3G Reciever we bought the Teradek Battery Plate for Sony L-Series to 2-pin Lemo. http://www.bhphotovideo.com/c/product/845755-REG/Teradek_BIT_635_Battery_Adapter_Plate_for.html
    Now to mount the battery plates we did need to do a bit of modifying to the battery plate tray but all in all it was pretty simple stuff. We needed to drill and tap a 1/4-20 hole for the Ikan battery plate in order to mount it as shown (its the plate on the right). We ordered the following #7 drill bit http://www.mcmaster.com/#3146a179/=ov48ac. Then we tapped the hole to 1/4-20 with an Irwin Tap set. We also used a 1/2" Countersink bit to widen the central mounting hole to accept the 1/2" 1/4-20 Screws we had on hand (http://www.mcmaster.com/#90585a537/=ov4c3f).
    For the Teradek power, luckily there was a hole in the monitor frame that lined up perfectly so we simply had to widen the hole and tap that one as well.
    Overall the setup works really well. We ended up mounting the AC7 upside down to make cable access a bit easier. The unit is fairly front heavy so I'll be ordering the extended mounts for the transmitter tray but the setup works for now.
    Anyways hope this helps those of you looking to set this type of unit up.
    Mike
    Ikbal Arafa, John Pope and Kyler Zee like this.
  8. Frank-Michael Krause
    May 29, 2013
    22
    Just wanted to throw this one in:
    We are using a DP6 on the Secraft TX Tray. It fits perfectly!
  9. Kevin Winkler
    Sep 9, 2013
    im glad it fits, the AC-7 does fit but it def puts pressure on the screw and is not idea especially when taking it on and off. We are getting a bracket made. If anyone else has a solution i would love to hear
  10. Sam Windell
    Sam Windell Member
    Dec 2, 2013
    47
    I mounted the AC7 to the TX tray secraft sells. It is rather tight on the screws. I went to home depot and bought 6-32 threaded screws that are longer than the standard ones. I was able to screw them in to hold the LP-E6 battery adapter plate on, although pressure is pretty tight on screws still. I recommend shaving off part of the curves with a razor that the battery mount plate has near the screw holes for the AC7 if you plan on powering with canon batteries. Helped make it flatter to mount to the metal TX tray. Would love to see someone that made a bracket that may help with stress on screws. I should probably just splice a lipo to power both the monitor and paralinx to save myself the trouble of powering and mounting canon batteries.
  11. Andrew Hewson
    Andrew Hewson Member
    Oct 1, 2013
    44
    Did you guys get the Large TX Tray or the small?
  12. Mike Duval
    Mike Duval Member
    Apr 24, 2013
    66
    18
    We got the small TX Tray Andrew.
