Hello all As an alternative at the Y6 to have more front visibility i was thinking at a solution to put the front arm higher ... And i just discovered that i wasn't alone to think about it : http://holco.nl.picturepush.com/alb...er.html#column2::/album/175723/detail/8189669 Did someone tried that on cinestar6 ? Any feed back ? thanks Denis
I've wondered about doing that, Denis. You could probably do a "dog-leg" boom #1 with a couple of boom-clamps used to connect two shorter booms -- you'd need to run the motor wires down the outside of the booms I would think. If would only be viable for a 2-axis gimbal, of course... I don't know if any of the forum members have done that though. Andy.
