MK YAW ISSUES
Discussion in 'Electronics' started by Alex Smart, Jan 3, 2014.
  1. Alex Smart
    Alex Smart Member
    Dec 5, 2012
    100
    10
    Hi !
    Lately I'm having 90 yaw spins and then it spins back!!
    I using a Dodecacopter, Hexa coaxial, it has been really stable till now but something seams to be failing...
    Basic checks done/all motors spining in right direction/all props are tight...
    FC2.2
    BL2.0
    MK3638
    10,371
    Is this on a Cinestar frameset, Alex?
    It could be that you've got a connection problem between the FC and power distribution board that's causing "twitches" on the I2C bus between the FC and the PDB.
    From what you say, you don't have a Navi Control board so you will not be able to get flight log data, right?
  3. Alex Smart
    Alex Smart Member
    Dec 5, 2012
    100
    10
    Hi Andy,
    Im sorry its not a Cinestar frame set, its a custom one just to try new combinations.
    The thing tho, is that it has been flying great till now that it has this yaw issues..
    I´m attaching the gpx file, you can see that there is a BLError 24 caused by temp, I think is just a faulty sensor,all are running good and heating up around 50C, the downside as you will see is that Im using a HERIKA HEXA Mixer and aded the other 6 motors, I think that is the reason for only loging 6BLs.No IC2 errors anyways..
    Maby you can see something that I´m missing?
    10,371
    Hi Alex:
    Sorry, I don't know enough about dodecacopters, I'm afraid. I'm not sure how many folks are flying your kind of configuration. If you don't get a response here, you may have better luck at getting a response from mikrokopter.de (the English forum).
