MK GPX
Discussion in 'Software Solutions' started by Janne Hoglund, Jun 12, 2013.
  1. Janne Hoglund
    Janne Hoglund Member
    Oct 4, 2012
    364
    23
    Hi All.
    With the new GPX I think I have heard that you can have a look at your logfiles from inside MK tools??
    I can get to see the files on the memorycard but not open them :-(
    Something I am doing the wrong way maybe?
    Regards all
    /Janne
    You need to download the file. Can not be run within MKTools. Downside is that you can't download a folder, only one file at a time.
  3. Janne Hoglund
    Oct 4, 2012
    364
    23
    Thanks Gary.
    Did that but as you say only one file at the time, and at an awefully slow speed :-(
    So much faster watching and comparing files the old way.
    Regards.
    /Janne
  4. Haidee Yatim
    Haidee Yatim New Member
    Aug 7, 2012
    Hi Guys,
    Just did a firmware update (2.06a) on my CS6 running MK stacks and fitted Tiger MN 3215 400KV motors swinging graupner 14x8 props,test flown it today and experience motor/s crackling and wasnt sure if its a timing issue and seems its trying to stall,got a weird noise and seems somethings not right...,i cant figure out whats on the GPX data and was hoping if someone here can share some light?Many Thanks in advance?
    Track that caused Error: 3
    Error: System.InvalidCastException: Conversion from string "0</TargetD" to type 'Double' is not valid. ---> System.FormatException: Input string was not in a correct format.
    at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
    at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
    --- End of inner exception stack trace ---
    at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value)
    at MK_GPXTool.Main.ShowGPXData()
    <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
    <gpx creator="NC" version="2.0" >
    <metadata>
    <link href="http://www.mikrokopter.de">
    <text>MikroKopter</text>
    </link>
    <desc>FC HW:2.2 SW:2.06a + NC HW:2.0 SW:2.06a BL:V2</desc>
    <extensions>
    <MK_Time>538min</MK_Time>
    <License>
    <info>No License installed</info>
    </License>
    <settings>
    <Number>3</Number>
    <CompassOffset>0</CompassOffset>
    <FCOrientation>0</FCOrientation>
    <GeoMag>-2</GeoMag>
    <MagSensor>internal</MagSensor>
    <MaxAltitude>150</MaxAltitude>
    <Bytes>6b,f2,44</Bytes>
    </settings>
    </extensions>
    </metadata>
    <trk>
    <name>Flight</name>
    <trkseg>
    <trkpt lat="+55.9433730" lon="-3.5605738">
    <ele>13.443</ele>
    <time>2014-04-24T19:10:43.6Z</time>
    <sat>8</sat>
    <extensions>
    <FlightTime>3</FlightTime>
    <ErrorCode>000</ErrorCode>
    <FCFlags2>0x00,0x00</FCFlags2>
    <NCFlag>0xC1</NCFlag>
    <Speak>48</Speak>
    <Altimeter>264,' '</Altimeter>
    <Variometer>81</Variometer>
    <Voltage>19.9</Voltage>
    <Current>10.9</Current>
    <Capacity>34</Capacity>
    <Compass>162,173,162,159</Compass>
    <MagnetField>125</MagnetField>
    <MagnetInclination>63,-7</MagnetInclination>
    <NickAngle>5.2</NickAngle>
    <RollAngle>-0.1</RollAngle>
    <MotorCurrent>22,25,17,17,9,19</MotorCurrent>
    <BL_Temperature>8,8,12,9,9,10</BL_Temperature>
    <MotorNOK>0,0,0,0,0,0</MotorNOK>
    <AvaiableMotorPower>255</AvaiableMotorPower>
    <FC_I2C_ErrorCounter>000</FC_I2C_ErrorCounter>
    <FC_SPI_ErrorCounter>000</FC_SPI_ErrorCounter>
    <AnalogInputs>32,42,45,25</AnalogInputs>
    <Servo>128,128,0</Servo>
    <WP>----,0,0,0</WP>
    <TargetBearing>000</TargetBearing>
    <TargetDistance>0</TargetDistance>
    <Course>223</Course>
    <GroundSpeed>269</GroundSpeed>
    <VerticalSpeed>288</VerticalSpeed>
    <RCSticks>23,37,47,-6,0,0,115,0,126,131,0,255</RCSticks>
    <GPSSticks>0,0,0,'/'</GPSSticks>
    <RCQuality>205</RCQuality>
    </extensions>
    </trkpt>
    <trkpt lat="+55.9433622" lon="-3.5605921">
    <ele>14.962</ele>
    <time>2014-04-24T19:10:44.2Z</time>
    <sat>8</sat>
    <extensions>
    <FlightTime>4</FlightTime>
    <FCFlags2>0xc3,0x10</FCFlags2>
    <Speak>0</Speak>
    <Altimeter>300,' '</Altimeter>
    <Variometer>47</Variometer>
    <Voltage>19.6</Voltage>
    <Capacity>36</Capacity>
    <Compass>154,134,151,151</Compass>
    <MagnetField>121</MagnetField>
    <MagnetInclination>65,-5</MagnetInclination>
    <NickAngle>9.2</NickAngle>
    <RollAngle>14.8</RollAngle>
    <MotorCurrent>29,25,17,17,6,12</MotorCurrent>
    <AnalogInputs>33,29,44,33</AnalogInputs>
    <WP>----,0,0,0</WP>
    <Course>222</Course>
    <GroundSpeed>291</GroundSpeed>
    <VerticalSpeed>144</VerticalSpeed>
    <RCSticks>20,50,99,20,0,0,115,0,126,131,0,255</RCSticks>
    <RCQuality>199</RCQuality>
    </extensions>
    </trkpt>
    <trkpt lat="+55.9433540" lon="-3.5606036">
    <ele>15.335</ele>
    <time>2014-04-24T19:10:44.6Z</time>
    <sat>8</sat>
    <extensions>
    <Speak>0</Speak>
    <Altimeter>326,' '</Altimeter>
    <Variometer>29</Variometer>
    <Voltage>19.4</Voltage>
    <Current>15.0</Current>
    <Capacity>37</Capacity>
    <Compass>122,120,136,119</Compass>
    <MagnetField>123</MagnetField>
    <MagnetInclination>67,-3</MagnetInclination>
    <NickAngle>9.4</NickAngle>
    <RollAngle>25.3</RollAngle>
    <MotorCurrent>29,15,36,17,6,12</MotorCurrent>
    <BL_Temperature>8,9,13,9,9,10</BL_Temperature>
    <AnalogInputs>33,38,44,35</AnalogInputs>
    <WP>----,0,0,0</WP>
    <Course>211</Course>
    <GroundSpeed>273</GroundSpeed>
    <VerticalSpeed>78</VerticalSpeed>
    <RCSticks>12,51,97,19,0,0,115,0,126,131,0,255</RCSticks>
    <RCQuality>208</RCQuality>
    </extensions>
    </trkpt>
    <trkpt lat="+55.9433426" lon="-3.5606086">
    <ele>15.628</ele>
    <time>2014-04-24T19:10:45.2Z</time>
    <sat>8</sat>
    <extensions>
    <FlightTime>5</FlightTime>
    <Speak>0</Speak>
    <Altimeter>335,' '</Altimeter>
    <Variometer>23</Variometer>
    <Current>14.9</Current>
    <Capacity>40</Capacity>
    <Compass>091,107,090,088</Compass>
    <MagnetField>128</MagnetField>
    <MagnetInclination>69,-1</MagnetInclination>
    <NickAngle>1.2</NickAngle>
    <RollAngle>14.0</RollAngle>
    <MotorCurrent>9,15,36,21,11,34</MotorCurrent>
    <BL_Temperature>8,9,13,10,9,10</BL_Temperature>
    <AnalogInputs>31,38,42,15</AnalogInputs>
    <WP>----,0,0,0</WP>
  5. Andy Johnson-Laird
    Haidee:
    GPX files are text files encoded in XML (eXtended Markup Language). You need to use a program like MK_GPXTOOL to display the data in a useful form.
    Check out http://www.mikrokopter.de/ucwiki/en/MKGPXTool -- you can also download the software there as well as getting some documentation.
  6. Haidee Yatim
    Aug 7, 2012
    Andy,
    Managed to sort the jargons with the new GPX tool.Thanks again :)
    Haidee
  7. Andy Johnson-Laird
  8. Steve Maller
    Andy, you’ve served all of us to such a huge extent. “Self-serving” is a rather absurd characterization. In my house, you’re referred to as “Saint Andy”. :rolleyes:
  9. Andy Johnson-Laird
    I'm known for my absurdity.... :)
