Enough off MK 2.0 Back to 1.80!! No problem with downgrading the FC and NC. BUT using latest 1.80 as soon as I enter settings ...the sw.chrash :-( 2.0 wont connect to the MK using 0.90j and 1,78 does connect but the settings window is disabled ;-( I want to use 1.80 and 0.90j any ideas?? The best sw they made, I and many others seem to think. Please help me this 2.0 stuff cost me two days now :-(
Hi Janne, Not sure what you mean, but it seams you are running a incompatible versions of MkTools and FC. Make sure they end in the same number? On tthe other side,V2.o is working very good on my craft Regards, A
There is an extensive discussion of this firmware version and its problems here: http://forum.freeflysystems.com/index.php?threads/new-mk-firmware-beta-0-91-as-of-14-06-2013.1674/ I have had good results with it. Others have not.
Lots of toilet bowling in 2.0! Alt hold was soooo nice in previous sw not so in 2.0! The only way to get motors started since uppgrade is to set reciever to Hott?! A bit weird since this copter has beeen used with Futaba since 2010!!
You need to use the corresponding MKTool version. If you have a version mismatch then that may explain the error.
