Minimum voltage?
Discussion in 'MōVI M10' started by Carl F. Coates, Oct 2, 2014.
  1. Carl F. Coates
    Carl F. Coates New Member
    Nov 21, 2013
    20
    What is the minimum Voltage that a MoVi 10 will operate?
    Carl about 14 volts is the minimum. The standard LiPo 4S battery shouldn't typically go lower than 14.4 volts. It is considered dead and likely can't be recharged at 12.8v. Also as it gets lower it begins to lose it's oomph and the gimbal may not respond to quick movements as well as a fully charged battery.
  3. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    138
    21
    Hey Carl,
    15.2 volts is the lowest I'll run a LiPo battery on an M10 before changing it. If we're about to do a long take or I have time at 15.4 volts, I'll change it then. A good rule of thumb is to change the battery shortly after the first LED light goes out on the power indicator on the back of the MoVI. I usually have 4 LiPo's in rotation for any shoot I'm on.
  4. Carl F. Coates
    Nov 21, 2013
    20
    Thank you....I appreciate it
  5. Carl F. Coates
    Nov 21, 2013
    20
