Hi Rory can you share with us your cvs log file? can you check the motors temp in that specify flight. tks all the best
Changed the vimeo link to a direct link. Alexandre, sorry I no longer have the logs, well think I don't as I've been doing so much flying since this project. Is there anything in particular you wanted to know?
please what your gross weight ,ambient temperature and altitude flight? around+-, iam trying fly 13,6 kilos total weight but with a lot motor temp inssue, its pretty light setup 2.260kl camera with lenses ,motor,link and m15, all the setup reach 13,6 kilos. my motor temp go up to 70c somethimes go 90c. with the new firmwire update theres a alarm set to 70.c all the best picts bellow
Try QC 6.000 mHa batteries or Tattu 6.200 mHa... you are going to reduce almost 1 Kg from the total setup... still 8 to 9 minutes of flight... and I´m using a Tattu 4S 4.000 mHa for the Movi10 / connex / Red / follow focus (25 minutes running time for all that setup) and a lot of weight saved... (12,3 kilos)
tks i will try that but good to know that after invest in more than 10 freefly original batteries, thats the way it is....
