Mimic problem
Discussion in 'MIMIC' started by Riccardo Besantini, Jun 12, 2016.
  1. Riccardo Besantini
    Riccardo Besantini New Member
    May 29, 2016
    This isnthe message that I have when I connected the Mac to the Mimic:
    "Device is connected but not responding. Do not continue if the device bootstrap jumper is not in place! Do you wish to continue?"
    Someone can help me!!
    thank you.
    Ricardo what are you trying to do? Software update? Do you have the jumper? It is used if you lock up the system that you are trying to update.
  3. Riccardo Besantini
    May 29, 2016
    I Gary, I would like to update the softwere, but I can't linking the mimic with the bleutooth and also with wifi adapter. Yes I have the jumper but do you know how I can use it? When i bind both device, the green light of both has the same blinking all the time.
  4. John Byron Hanby IV
    John Byron Hanby IV New Member
    May 22, 2016
    Just had same problem this is how I fixed:
    Download MIMIC 1.4 Firmware here: http://freeflysystems.com/software-manuals/beta/software-by-product
    Connect Unplug the 5 pin from the Mimic Transmitter leave plugged into the bigger GPS AND ANTENNA BOX
    Short pins 1 & 5 with some kind of thin wire. This will cause reset firmware mode to enable
    Leave the shorted wire in for the rest of the update
    Plug in the USB cable to power source
    From computer open the Movi App and connect via bluetooth
    It will ask if you are sure you want to continue? say yes
    upload the MIMIC 1.4 Firmware to the mimic.
    unplug mimic from power source
    remote the 5 pin cable short
    plug 5 pin back into smaller MIMIC transmitter box
    plug mimic back into battery to turn on
    problem solved.
    hope this helps.
    Best,
    John
