mimic + movi controller
Discussion in 'MIMIC' started by Joseph Jang, Jul 1, 2015.
  1. Joseph Jang
    Joseph Jang New Member
    Dec 10, 2013
    18
    Hi guys.
    I've updated the M15 and movi controller to the beta firmware and got the mimic function to work on the controller with the M15. It's amazing. However, when the mimic function is turned on, the begins to slowly pan by itself even when the controller is not moving. Any ideas as to the cause and possible solutions?
    Thanks in advance!
  2. Austin Glass
    Austin Glass Active Member
    Aug 1, 2013
    440
    69
    In the part of the menu where you switch between "normal" and "Mimic" functions, you can roll the dial further right and select "re-zero" which should help. When you press to select, make sure you are holding the Controller perfectly still, or have it set down level on a surface.
  3. Even Sigstad
    Even Sigstad New Member
    Jan 2, 2014
    23
    10
    This happend to me when the Movi controller were low on battery. Try changing to a fully charged one, might help!
  4. Aleksandar Bracinac
    Aleksandar Bracinac New Member
    Jun 28, 2015
    I've added Pan and Tilt trim to User 2/3 and fixing that some how. Is there any way to calibrate the Controller to perfect zero?
  5. Aleksandar Bracinac
    Jun 28, 2015
    And yes, there is the difference when you powering Controller from USB and from V-batt
