MIMIC and ALTA
Discussion in 'ALTA' started by alex ryan, Nov 11, 2015.
  1. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Just wondering if anyone is using the MIMIC in conjunction with the ALTA?
    Whats your set up, take off and landing procedure?
    I'm interested to know how people get around the fact that there isn't a kill, or lock function with the MIMIC.
  2. Jack Wrangham
    Jack Wrangham Member
    Feb 28, 2013
    64
    We found that we can actually have both a futaba rx and mimic rx plugged in at the same time, so we use our futaba gimbal tx as normal, using the kill/park switch when on the ground etc. The mimic overrides the other control functions, so when turned on it controls the movi, but the kill switch on the tx still works. It's works pretty well, also means we can revert back to tx control whilst airborne if needed by just turning of the mimic.
  3. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    oh cool. Thanks for the tip.
    10,364
    Good find, Jack. Interesting solution!
  5. Steve Maller
    3,979
    Jack, what kind of range are you seeing with the MIMIC airborne?
  6. Jack Wrangham
    Feb 28, 2013
    64
    Hey Steve, we were only getting 100m or so which wasn't enough, now using a 2.4ghz wifi signal booster and getting the 500m we need easily (max legal distance here in the UK). I don't know why the standard range is so short - I would have thought range would be as good as a standard radio tx - spectrum or futaba! But I guess the mimic tx must have much less power for some reason...
  7. Adam Etheridge
    Aug 23, 2013
    52
    Hi Jack. Which signal booster are you guys using?
  8. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    I second Adam's question.
