M5 with BMPC 4k... what lenses are you using??
Discussion in 'MōVI M5' started by Mike Percelli, May 8, 2014.
  1. Mike Percelli
    Mike Percelli New Member
    Mar 13, 2014
    20
    Just wondering what lenses everyone is using with their M5 and the Black Magic Production Camera?
  2. Joe Lawry
    Joe Lawry Member
    Sep 9, 2013
    42
    Trying to do the same thing. It seems the Sigma 18-35 is the only lens that will balance correctly.. This is annoying.
  3. Steve Maller
    3,979
    That’s strange. What prevents you from balancing with other lenses?
  4. Tim Joy
    Tim Joy Active Member
    Aug 2, 2012
    405
    72
    I had no real luck balancing with the Blackmagic 4k. Seemed like a lot of extra weight was necessary on the camera left side to balance the roll, especially considering it puts the SDI output right on the tilt rails. I'm sure it's possible to do, but to me it wasn't worth the finagling.
  5. Mike Percelli
    Mar 13, 2014
    20
    We have tried numerous lenses... It's difficult. The shape of the camera has a lot to so with the balancing problems. If you look on Vimeo , they have a c100 with a 24mm L lens on it perfectly balance. Every time we email freefly support we get an answer that lens length is just as important as weight. Total weight is a total factor as well.. Let's compare the bmpcc and the c100
    Bmpcc- 3.75lbs
    C100- 4lbs
    Now let's look at the lenses
    We have been trying the rokinon 14mm 3.1 cine
    Rokinon- 1.4lbs
    Canon- 1.6 lbs
    So I want to know how the hell did they get the c100 to balance perfectly and we can't get our setup to.. The c100 is much heavier.
    We have spent numerous hours trying and can't get it.. We know the bmpcc does work with the m5 as freefly has not only stated it but has shown it in action with a few videos. Any other cameras we try we can get to balance immediately with perfect results. So it's not lack of knowledge knowing how to balance a camera properly.... FRUSTRATING !!!'
    Juan Diego Zacarias likes this.
  6. Chris Fox
    Chris Fox Active Member
    Apr 14, 2013
    463
    86
    G'Day Mike,
    What's the issue you are facing, I've happily balanced the BM4K on the M10 and M5... What are the symptoms that you are facing and have you got some pictures??
    We run the samyang lens and have balanced the lens to be all the same weight to make lens changes easier.
  7. Mike Percelli
    Mar 13, 2014
    20
    Chris,
    No matter what we do... We can't get vertical tilt correct. Please help!!!!
  8. Mike Percelli
    Mar 13, 2014
    20
    And what Samyang lenses are you having luck with ? Like instated we are trying the rokinon 14mm 3.1 cine
  9. Chris Fox
    Apr 14, 2013
    463
    86
    happily balancing the 16,24,35 and 85 ... haven't tried the 14
    What are you doing to test for the vertical tilt balance, are you pointing the lens up (or down) and sliding the rails forward or back to get the tilt balance? like in the videos?
  10. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Any way I could see some pictures of the M5 with the BMCC on it. We have a possible rental and I don't have any units in house to test. Would be much appreciated. Thanks
  11. Kurt Myers
    Kurt Myers New Member
    May 21, 2014
    I have managed to mount the BMCC with a zeiss 50mm 1.4 and a tokina 11-16. It's not ideal at all. The camera is too wide, and the weight is not centered, so you have to add a counterweight as you cannot slide the camera left or right. Has anyone had any monitoring solutions for it? There doesn't seem to be enough space for a bnc. Also, with the camera and 11-16, you're already at 5.5lbs. That's without any counterweight. It does balance, but I don't want to go throwing on much more weight.
  12. Ryan McMaster
    Ryan McMaster Active Member
    Mar 8, 2014
    289
    40
    Never had an issue with the BM 4k , Canon 10-22 and 10-18 rock on it.
  13. Joe Lawry
    Joe Lawry Member
    Sep 9, 2013
    42
    I got there eventually, added a 2s lipo right on top of the horizontal arm that the tilt motor is mounted too. Balanced everything out.
    Flying with a canon 16-35 and its great, better than the m10 i reckon!
  14. Dan Proud
    Dan Proud New Member
    Jan 1, 2013
    How are you guys getting the SDI cable plugged in to the camera? I'm able to balance all good but the SDI ends up right next to the rails, no room for a cable. I guess using the external monitor is not an option! Any ideas?
  15. Chris Fox
    Apr 14, 2013
    463
    86
    You need more weight on the front of the camera to slide it back further so the SDI cable can connect. Different lens or adding a FFS will all do it .... Or some of Andy's magical self adhesive led tape works as well.
  16. Dan Proud
    Jan 1, 2013
    Thanks for the ideas Chris! I found some parts from an old panoramic tripod head that bolted right on. Balances easy now with access to the SDI port. Sweet!
  17. Chris Fox
    Apr 14, 2013
    463
    86
    glad to see you have some success ;)
  18. Ryan McMaster
    Mar 8, 2014
    289
    40
    Here is how I mount my BM 4k+Canon 10-22, Canon 24mm f/2.8 and 35mm f/2 (both the IS models). We use a Teradek bolt mounted to the back of the camera via custom mounting plate (3rd pic). We use 4" and 6" carbon rods in place of the stock rods. This gives us full access to the SDI out, and power (4s lipo runs the cam, downlink). So far this thing has been rock solid. The non test bolt will be here tomorrow or Thursday, ill post a follow up then.
  19. Ryan McMaster
    Mar 8, 2014
    289
    40
    Bolt, 4k, M5. Tested today and holy crap its so much better then the old method. bolt4k.jpg
    Korey Clark likes this.
  20. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Ryan,thanks for that great tip! I also balanced M5 with BlackMagic 4K + Zeiss Distagon 18mm lens without any issues. SDI out is fully accessible.
