Hi guys yestrday I bought movi and i have problem with video quality stabilization. Can you recommended some good set up which are you using? video: my setup Canon 5d markIII with canon 24mm obj. pan stiff: 63 roll stiff: 30 tilt stiff: 15 Autotune 50% pan,roll,tilt strenght 10 gyro filter 5 Output filter 5 antivibration system from kopterwork http://kopterworx.com/shop/movi/movi-m5-adapter-for-dji-s1000-frame.html Thanks guys
Flip welcome to the forums. Would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/.
Your numbers look way off from what I use. My stiffness numbers are nearly twice what you have, and the filters are 3/3. Look in the Google doc for some better numbers. https://docs.google.com/spreadsheets/d/1nJ8nChupA_lhoRsXVuUpWlxBL2rTtVDEXY3nQaSGRbs/edit#gid=0
