Hey guys, would the M5 be a good match for the Canon C100? The camera didn't make the cut for the M5/M10 compatibility chart, so I'm not sure. Depending on glass, it makes the M5 weight specs, but it's somewhat taller than a DSLR.. Thanks!
I would assume since the C100 is basically the same form factor as the 300 and 500 that it would work with the M10. Weight wise you may find the M10 would be a better choice also.
