M5 and the "GPS Maxtenna"
Discussion in 'MōVI M5' started by Rob Noah, May 11, 2015.
  1. Rob Noah
    Rob Noah New Member
    May 13, 2014
    I ordered a GPS Maxtenna (link below) for my M5. But, it won't fit the antenna mount. Am I missing something obvious, or is this antenna not intended for use with the M5 (the product page doesn't say). I could cut off the existing antenna mount to fit the Maxtenna, but hate to do something destructive without being certain it's a good idea. Anyone use this antenna with an M5?
    http://store.freeflysystems.com/collections/movi-accessory/products/gps-maxtenna
  2. Josh Lambeth
    1,315
    216
    Good to know. I almost ordered one yesterday. Curious to hear what is said.
    Side note, why are you ordering one? Are you having issues with not getting enough sats? I had 6 the other day but the FF app said I still didn't have a valid lock?
  3. Rob Noah
    Rob Noah New Member
    May 13, 2014
    No issues -- have been using it hand-held for a while now and am getting ready to get it into the air.
    I'd suggest opening up a support ticket by emailing to support@freeflysystems.com -- seems odd that it would not fit, doesn't it?
  5. Jeff Scholl
    Jeff Scholl Distributor
    240
    50
    I had to take a snipper and trim a bit off the plastic housing for the Maxtenna.
    Jeff
    Taylor Davis likes this.
  6. Rob Noah
    Rob Noah New Member
    May 13, 2014
    Thanks for that. That's what I was thinking of doing, but wanted to be sure I wasn't just missing some obvious alternative. I guess this antenna is not intended for the M5. Have you noticed better GPS reception with it on the M5?
  7. Jeff Scholl
    240
    50
    I flew around 30 flights with the new Maxtenna on the M5/Sony A7s this weekend and had solid level horizons.
    Best,
    Jeff
  8. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    Jeff, did the antenna make a noticeable improvement?
  9. Christer Dahl
    Christer Dahl Member
    May 14, 2015
    38
    Yea Jeff, i wonder about the same!
    Anyone know if any european dealers have these in stock?
  10. Andrew Griffiths
    Jul 7, 2013
    61
    We tested both antennas in an urban environment and didn't see any improvement over the standard antenna.
