Hi all, The tilt axis on my M15 is misbehaving. The Max and Min tilt parameters are set to their max and min and the most it will tilt is about 30 degrees both up and down. This is both in majestic mode and using the joystick on the controller. When it gets to the 30 degree (approx) angle it goes a little soft on the stiffness side and can be wobbled if the Movi is moved back and forth. When I move the camera back down towards centre postion it stiffens back up. Troubleshooting and actions taken: - Have updated firmware - Reset to factory settings and autotuned - Checked wiring and all seems ok Any thoughts or possible solutions would be much appreciated. Cheers, Pete
Hmmm. That is odd. It might be time to email to support@freeflysystems.com and open up a support ticket if you have not already done so. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
