Hi, on a recent job I was working with an M15 that wanted to swing from sided to side on its pan axis. After lowering motor stiffness and building it back up the problem was still apparent. removing the gimbal from the top bar and relocating it worked as a quick fix but after a few shots the issue resumed. it was also apparent after power down-powerup. The issue would cease in Aerial mode but continue when switched back to hand held mode. Has anyone encountered this issue? Do they know what causes it and how it can be fixed? Thanks
Edward welcome to the forums. Would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/. Sounds like a balance issue. Review the setup instructions and the videos that are on the main Freefly Systems website. Also check the Zendesk at https://freeflysystems.zendesk.com/hc/en-us.
