M15 out at sea hot swap lipos
Discussion in 'MōVI M15' started by Charles Lim, Dec 23, 2014.
  1. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    I was wondering when we sea legs use the M15 out at sea. It's critical to have the Movi sensors on all the time. Is there a way to hot swap batteries so as to eliminate this issue?
  2. Austin Glass
    Austin Glass Active Member
    Aug 1, 2013
    440
    69
    Is there any reason you can't turn on motion booting, and just change batteries the traditional way?
  3. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    boat rocking like crazy out in open sea
  4. Austin Glass
    Aug 1, 2013
    440
    69
    Motion booting allows you to bypass the Movi's calibration upon start up. It means after it's enabled you can turn the Movi off and on all day long without requiring a still environment.
  5. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    how do you turn on motion booting?
  6. Gary Haynes
    It's one of the settings in the latest firmware/GUI.
  7. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    wonder if motion booting would work in real rough seas
  8. Gary Haynes
    Charles maybe you can try it on one of your shoots. Maybe when the boat is headed back to port and shooting has been completed?
  9. Austin Glass
    Aug 1, 2013
    440
    69
    My understanding is that it doesn't even try to read the sensors so I would assume a hurricane couldn't deter you!
  10. Dave Ketelhut
    Dave Ketelhut Member
    Jan 17, 2014
    34
  11. Andy Johnson-Laird
    10,356
    1,161
    Just don't leave the discharged battery and charged battery both connected for too long -- the charged one will be trying recharge the discharged one at a pretty high current and that's definitely a Bad Thing. So do the hot swap as fast as you can consistent with safety, e.g. connect up new battery and immediately disconnect discharged battery.
  12. Andrew Hewson
    Andrew Hewson Member
    Oct 1, 2013
    44
    They told us at Quadrocopter that the motion booting is great but after time it deteriates.
  13. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Motion booting might not work if it's too shaky. So, I'd opt for hot swapping lipos for the peace of mind. If you have soldering skills, it's very easy to build a cable for this.
