M15 mounted to a Crane
Discussion in 'MōVI FAQ - Tips and Tricks' started by Robert Pflumm, Nov 19, 2014.
  1. Robert Pflumm
    Robert Pflumm New Member
    Oct 31, 2014
    10
    Has anyone done this with the handles? I have the TiTH and the ninja star but I am looking to disconnect the movi from the crane and continue the shot hand held with the handles already attached. Thanks.
  2. Ben Ruffell
    Ben Ruffell Active Member
    Jan 15, 2014
    227
    33
    Yes. My grip made a rig out of clamps and things. Three points of contact. It worked fine.
    (We were in a small town with an old crane, and had to come up with a solution...)
  3. Chris Gerding
    Chris Gerding Member
    Apr 10, 2014
    34
    Mount another hole on top of the bars and a toad on the crane.
    Or, mount a Cardellini on the crane and LIGHTLY snug it down onto the center top handle. When the crane comes down, looswn the Cardellini and slip the Movi out.
    I hope it's obvious that the crane grip must hold onto the arm when you remove the weight of the Movi.
  4. Robert Pflumm
    Oct 31, 2014
    10
    Yes it is. Thanks for the reply.
  5. Kevin Descheemaeker
    Sep 16, 2013
    59
    Hi Robert
    We just made a sandbag with the same weight of the complete MōVI setup, when the crane comes down the MōVI operator picks up his rig and in the meantime we hang the sandbag as counterweight.
  6. Jason Comparetto
    Sep 23, 2013
    269
    38
    This is what we use for jib shots --
    [​IMG]
    Its the Cinema Oxide C-stand adapter for Movi. Its has clamps built into the hooks so that you can secure the handle bar to the jib, and then continue the shot handheld if you want. In this photo you can also go overslung with the Movi, achieving a higher angle on the jib. It has 3/8" tapped holes and 1/4" tapped holes on the baseplate to allow it to mount to any jib or tripod plate. It sounds like the OP can just go underslung with the Movi, so this will be even simpler.
  7. Jonathan Ross
    Jonathan Ross Member
    Jul 29, 2014
    113
    10
    Yes, Works great especially with a Redwing boom for mini jib jobs indoors. The Redwing keeps the angle true.
  8. Nicholas Stich
    Nicholas Stich New Member
    Nov 1, 2014
    jim mundell likes this.
  9. Jonathan Ross
    Jul 29, 2014
    113
    10
    Thanks added it to our growing links list.
