M15 batteries replacement
Discussion in 'MōVI M15' started by Lucas Pruss, Sep 24, 2018.
  1. Lucas Pruss
    Lucas Pruss New Member
    Jun 13, 2018
    Hey guys,Was looking for an answer on the forum but with no luck.
    Just bought a M15 with no batteries due to transportation safety. What kind of battery replacement would You recommend to pair with M15? Also would like to ask on the possibility of M15 ring purchase, Europe area preferred,
    appreciate
    Lucas
    Lucas:
    You need to find a battery that matches the specifications here: https://store.freeflysystems.com/collections/legacy/products/freefly-movi-battery
    Specifically you'll need to match the physical dimensions, the fact that the battery is four cells (aka "4S"), Lithium Polymer ("Lipo"), 14.8 volts when fully charged, and with a "JST" two-pin power connector (small red connector in the image on the web page at the link above) with a JST balance lead (white connector in the image). You will need to use the JST red two-pin connector to connect up to the charger (for the actual overall charging) and the white JST connector for the charger to do the internal balancing of the voltage between all four cells.
    Hope this helps.
  3. Dan Wilson
    Dan Wilson New Member
    Jan 16, 2016
    24
    We use Overlander 2900mAh 4S 35C LiPos on ours. They are an incredible improvement over the Freefly batteries and go for about 3-4 hours. I did have to snip the stock power connector off and add one of the JST RCY connectors like the original batteries.
    But definitely worth it.
    John W Butler likes this.
