MōVI Pro Roll-Axis aggressive “twitch”
Discussion in 'MōVI Pro' started by Chad Copeland, Dec 15, 2019.
  1. Chad Copeland
    Chad Copeland New Member
    Feb 8, 2013
    17
    Flying the MōVI Pro under the ALTA 8, RED, Nucleus motor, RED control function (working) under the command of the MōVI Controller set for airborne...
    After take off the MōVI Controller was armed and upon an immediate flip of the switch, the gimbal began to aggressively roll the camera cage in a twitching back and fourth behavior.
    Why is it doing this? What is the fix?
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    878
    70
    did u autotune it before take off? sounds like the settings where wrong??
  3. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    137
    21
    Which switch did you flip before the MoVI went haywire? Did you use the app to make sure you’re in the MoVI Controller mode?
