MōVI Controller and RedRock Wireless 3.0 firmware issue
Discussion in 'MōVI Controller' started by Jon Firestone, Apr 22, 2015.
  1. Jon Firestone
    Jon Firestone New Member
    Mar 30, 2014
    10
    The new 3.0 firmware for the RedRock Wireless FF no longer works properly with the MōVI Controller. They've increased the resolution by 3 or 4 times, so now the MōVI controller only moves a small amount rather than the whole focus scale.
    The Redrock update is located athttp://store.redrockmicro.com/updatemygear.html
    Charles Bergquist likes this.
  2. Charles Bergquist
    Aug 15, 2013
    89
    28
    Thank you for this heads up Jon, almost just updated it!
  3. Daisuke Ide
    Daisuke Ide Distributor
    Jul 26, 2012
    34
    I also tried it. It was the same phenomenon. In V2.0 it works normally.
    It seems to need something changed in the MoVI Controller side in order to solve this problem.
  4. Charles Bergquist
    Aug 15, 2013
    89
    28
    Any updates on this issue yet?
  5. Hi Charles,
    A Support ticket was submitted today, we will look into it and post back when we have more information.
    Best Regards,
    Denise
  6. Peter Lay
    Peter Lay Member
    Apr 11, 2015
    51
    Any update on this? Is it possible to downgrade the firmware on the RR basestation back to 2.0 so it works properly with Movi controller?
  7. Hi Apachemedia - At this time it slated for the next firmware release but at this time I do not have a date scheduled. Also, please note that we do require your actual first and last name for your forum profile, if you could change yours, that would be most appreciated.
  8. Charles Bergquist
    Aug 15, 2013
    89
    28
    Just checking back if this is working yet.
    Peter Lay and Andres Torres like this.
  9. Peter Lay
    Peter Lay Member
    Apr 11, 2015
    51
    Second that. Are we any closer to the firmware update needed to address this issue? Thanks
  10. Charles Bergquist
    Aug 15, 2013
    89
    28
    Any updates?
    Peter Lay likes this.
  11. Charles Bergquist
    Aug 15, 2013
    89
    28
    Freefly didn't update this thread, but for those that are following it. It appears that the new firmware addresses the issue of RR 3.0 firmware. I'll know later this week if it all works.
    Jonathan Ross and Peter Lay like this.
  12. Jonathan Ross
    Jonathan Ross Member
    Jul 29, 2014
    113
    10
    Please post your results thank you.
    Cheers,
    J
  13. Charles Bergquist
    Aug 15, 2013
    89
    28
    Works with some issues. Rec trigger on Controller triggers movement in lens motor and some times just doesn't work.
    Not stable as of now.
  14. Charles Bergquist
    Aug 15, 2013
    89
    28
    Update today.
    Still is picky, but with MicroRemote Firmware 4, you have to select MicroRemote 3 in Aux Input each time you power up your controller. Even with saving it doesn't save the preference. I have no idea why, it's annoying but it does work.
    I'd say it's a little more stable now, but the selection of the MicroRemote is something to be aware of.
  15. Jonathan Ross
    Jul 29, 2014
    113
    10
    we finally bout the bullet and went to the wedge, no trouble since.
