MōVI ‘Ninja Star’
Discussion in 'MōVI M10' started by Jacob Schwarz, Dec 14, 2013.
  1. Jacob Schwarz
    Jacob Schwarz Member
    Sep 3, 2013
    68
    19
  2. Joe Hell
    Joe Hell Member
    Apr 7, 2013
    31
    I think it's made to replace the top handle... you can probably make a quick release from this
  3. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    i would love to see a video tutorial of this in action with Steadicam, Tripods, Jibs, Car Mounts, etc.
  4. James Leonzio
    James Leonzio Member
    Sep 3, 2013
    71
    16
    Sounds like it could open up a ton of options. It says in the description that it replaces the top handle. Do you think they mean the top handle and crossbar as well? I could see that making more sense.
  5. Jacob Schwarz
    Sep 3, 2013
    68
    19
    ideally i could use this to mount a quick release to the movie gimbal and then a plate to the top handle so that i can just snap it on in the field.
    Mike Vickers likes this.
  6. James,
    Yes it does. If you look at the addition thumbnail images in the Freefly store you will see how it is mounted.
  7. Jacob Schwarz
    Sep 3, 2013
    68
    19
    could any one from freely share some more light on this Ninja Star?
  8. What information are you looking for exactly? I would be happy to answer any questions.
    Chris
  9. Jacob Schwarz
    Sep 3, 2013
    68
    19
    Chris,
    I would just like to know the exact hole and treading for the whole piece. Really i would like to know if i can still screw the top mount into this ninja if needed. if that is the case i might order two of these guys and make sandwich a quick release plate in the middle.
    Thanks,
    Jacob
  10. If you are talking about re-attaching the top cross bar after attaching the Ninja Star to the MoVI, then yes.
    Remember it will be offset by several degrees because the holes you use to reattach the cross bar are not perpendicular to the rig as they were before you attached the Ninja Star.
    Chris
  11. Jacob Schwarz
    Sep 3, 2013
    68
    19
    Just got it in the mail yesterday and it great. But it seems like i might need to order two to do a quick release system that i was hoping for. Any chance freely will come out with something that i can screw the crossbar into that will give me a 1/4-20 hole? Or should i plan on getting a second ninja to get the job done?
  12. Justin Marx
    Justin Marx Active Member
    Oct 3, 2013
    326
    26
    Didn't even see this thread! Hahaha, just posted this--
  13. Ben Bateman
    Ben Bateman New Member
    Oct 1, 2013
    14
    Here's another use for it (also in this rig are the new Epic/Scarlet v-mount plate and rod adapter):
    Mike Vickers and Justin Marx like this.
  14. Justin Marx
    Oct 3, 2013
    326
    26
    Are you able to pan? Looks like the pan bar hits?
  15. Wolfgang Armin
    Wolfgang Armin Active Member
    Sep 20, 2012
    291
    25
    That´s why I built an extension for my crane arm. But the MoVI is a great cranehead I love it!
  16. Erich Roland
    Erich Roland Member
    Sep 27, 2013
    44
    cool, remote head.
    I think a good application in this regard is for car work. To take out the wobbles and imperfections of road. someone should make a mount for rigging onto a car exterior.
  17. Norbert Blenk
    Norbert Blenk Member
    Sep 12, 2013
    52
    Don't forget the g-forces which occur while driving!
    A ten to twelve pound heavy block of metal and glass will be harmounted via four tiny little screws to a car.
    If you drive fast, you will have to brake hard.
    I can't imagine this will work very long...
  18. Ben Bateman
    Oct 1, 2013
    14
    It's the angle of the pic. It just clears - we're going to get a custom cheeseplate made for the jib to move it forward some more as it could be better.
  19. James Leonzio
    Sep 3, 2013
    71
    16
    Has anyone figured out a way to mount the ninja star without removing the crossbar? I have an application that I'd like to keep pan control manual while the MoVI is attached to a support system.
  20. James,
    Yes, you can physically mount the 'Ninja Star' between the pan motor and the top cross bar. Just be aware that it will be off by a certain degree because the holes to accomplish this are offset by a certain amount, therefore the top crossbar will not be perpendicular to the rig when in 'majestic' mode or single user.
    Chris
    Rich Spiess likes this.
