Hi all, this question is for the freefly guys Just wondering if is possible to have the movi´s low battery warning audible. The problem is that sometimes you are not keeping track of the batteries levels and it happens that is too late when you realize that you have to change the batteries so it shuts down. Would be great to have some sore of beeping to let you now you have to change batteries. Or maybe to have the warning set it up when the battery is at a 10% so you have the time to change it. greetings sebastian
I agree about raising the threshold for critical battery warning. When does it start the warning? 6% remaining? By the time I see it on the screen, the AC's can't get me batteries fast enough from the cart to keep it alive. I usually try to change batteries at 30%, so we don't run into the problem, but sometimes the Movi sits around waiting, and we forget. Of course, this is powering everything, not just gimbal, so it drains pretty fast. Personally, I don't want it beeping at me though, since that could be disruptive on set.
It starts at 20%. However the battery curve is not linear, so with systems that drain lot of power this might not be enough time? Thinking the following to improve the feature. Let me know what you guys think. Add yellow warning at 40% (on top of the red one at 20%).
