I’m flying the MoVI 10 on my C8 for the first time on a shoot. Everything seems to be find except when we get past 100 yards and then we loose all control of the MoVI. It seems to turn 90 degrees with no control. We are flying around 75’ to 100’ above the ground. Once I bring the C8 closer to us, we regain control of the MoVI. Shouldn’t I have a longer distance range? Any tips or something i'm missing?
Check with support. Also follow the directions in the Spektrum Manual on Range checking. It may simply be that in that location you have RF causing and issue the copter carbon parts are blocking the receiver antenna, assuming you are using Spektrum. Try making sure the little antenna are straight out.
