hello, I‘m using the the MōVI pro in Beta 2.0.1 with the Mimic also in Beta 2. when i Switch from direct Mode the MōVI response with the mimic. When i then Switch to Level Roll the MōVI doesn‘t Level on the Horizont. What is wrong? Can someone help?
Does it follow the Mimic's horizon when you're in Level Roll, or does it just sit un-level? Can you make a video about it and post it so we can see the problem?
Hey Graham, I find a reason on my Own. In the majestic Settings was the Roll axis on majestic. So it overrides the Setting of the mimic Mode. And the mimic was Not in Level. I Switched the Roll in the majestic to Level and also the mimic worked in Level. Greetings from Germany and thank you Thorge
OK great! Thanks for following up with your solution. It can be helpful to others who may read this later.
Hello .. Hai I am using movipro with software version 1.5.3 beta. My problem is while taking the shot the gimbal 's roll axis gets small jerk. With in seconds roll axis came to normal position. And the shot get disturbs. I tried restarting gimbal and mimic, done reboot controller, done compass calibration . Then also roll axis gets same jerk. Please help me any one to get rid of this problem
What is your Heading Assist set to? Is it Off, Fixed, Compass, or GPS? If it's not already, I would try switching to Off and see if that helps.
