Level in Majestic Mode
Discussion in 'Movi Technical' started by Robert Muto, Aug 21, 2018.
  1. Robert Muto
    Robert Muto New Member
    Aug 9, 2018
    Anyone else have this issue. In Majestic mode with Roll and Tilt locks on the phone is level. Second I take tilt and roll lock off the phone goes on an angle off center. Have to adjust for that but can't get a level shot unless the locks are on. It used to be level but now only in locks. Just a iPhone 7 and simple case on there. It's balanced before turning it on. Also tried Auto Tuning and that didn't fix it.
    Bip likes this.
  2. Kevin P Riley
    Kevin P Riley Active Member
    Jun 21, 2018
    132
    29
    There are a couple of threads about this already, in which a Freefly staff member weighs in. The tilt lock should have nothing to do with it, you should be able to unlock tilt and still get a level image. When roll is unlocked....mine will start to drift off level even whe. Sitting o a level surface. They are aware of the issue.
  3. Simon Hughes
    Simon Hughes Member
    Jul 13, 2018
    45
    19
    Yup, same here. iPhone 6 with Moment V2 Wide with filter adapter and ND balances almost perfectly on all axises with Movi off/standby, but yaws slightly counterclockwise with Roll off. Annoying!
    @Deniz Ozgoren is there a adjustment that can be made accessible to allow us to trim the beast?
    Bip likes this.
  4. John Chu
    John Chu Active Member
    May 12, 2018
    106
    47
    I emailed Deniz with the same concerns a while back about level horizon issues with the Movi. Supposedly an upcoming beta will include a fix or method to trim it. Frustrating in seeing tilted horizons and having to rotate the footage and zoom in during editing. The Movi should have PERFECT horizons in use. Maybe a level indicator on the phone is displayed in and we dial in the horizon manually and save?
    Simon Hughes likes this.
  5. Edrolfo Leones
    Edrolfo Leones New Member
    Aug 15, 2018
    22
    11
    Speaking of which, I'm curious why Freefly didn't tap into the iPhone's accelerometer (and other sensors) to provide Movi with data analytics like pitch /yaw position levels, directional orientation, altitude, etc.
    In theory, it can even tell Movi which way the sun is facing at any given time and day, weather conditions, wind speed, etc.!
    Maybe in a future app release?
    EL
    Bip and John Chu like this.
  6. Warathanut Sukcharoenpong
    Jul 27, 2018
    30
    I believed this requires real time calculation and data transferring between Movi and the phone. This could potentially burn out some juice of battery for both as well as showing signs of delay response time.
  7. Robert Kadelka
    Robert Kadelka New Member
    Sep 10, 2018
    16
    Hi Guys,
    I have a similar issue. My horizon is not level in Majestic mode with Roll Lock on. There is a roll trim option in the settings, but it doesn't seem to do anything to the leveling.
    The issue is present with both my PlxelXL and my Note9
  8. Rorick Edge
    Rorick Edge Active Member
    May 11, 2018
    452
    81
  9. Robert Kadelka
    Sep 10, 2018
    16
    Rorick Edge likes this.
  10. Fadzil Firdaus
    Fadzil Firdaus New Member
    Sep 14, 2018
    I am having the same issue. After doing some experiments, I found out that the roll trim (landscape) is working only in smartpod mode, and majestic mode with tilt and roll locked.
  11. Fadzil Firdaus
    Sep 14, 2018
    I forget to mention that I'm using android beta apps. I'm not sure about ios version
  12. Robert Kadelka
    Sep 10, 2018
    16
    Roll trim isn't yet supported as far as I know, so we've gotta wait a little for this to happen. I'm gonna test it the way you mentioned
  13. Fadzil Firdaus
    Sep 14, 2018
    the way I did it was I switches accelerometer level app and movi app.
  14. Fadzil Firdaus
    Sep 14, 2018
    but it only works with smartpod. and majestic will tilt and roll locked. otherwise, it just tilted to the left
  15. Darryl Shelly
    Darryl Shelly New Member
    Aug 10, 2018
    Worked great for about 2 weeks, but now I can't get a level horizon. It seems like Movi is completely broken. I would gather that it's a software issue. I can't get it to stay level, and the phone wants to face towards the floor or directly to my left. I've tried other modes, but none of the modes work at all. I'm getting better footage by simply hand-holding the iPhone X. I've spent hours trying to get this going, but now I'm just fed up with it. I've asked for a refund even though I'm a little past the 14 day return.
  16. John Chu
    May 12, 2018
    106
    47
    Have you tried doing a reset and starting over? Do a reset in the Movi app, power unit down, slide the iPhone left and right until it is in the ballpark and then perform a custom tune.
  17. Darryl Shelly
    Aug 10, 2018
    I tried the reset. Doesn't work.
  18. Bip
    Bip New Member
    Oct 4, 2014
    Folks. As some others have mentioned, somewhat disappointing the FreeFly who I rate for their products ship this unit with a horizon issue. Gutted that I’m fiddling about with a beta app trying to level this and it’s still going off. Locked on roll and all that. What a shame as it’s beats the competition on paper but the practical use has left me so under whelmed. Not even a return to horizon function? Is this still a known issue with a fix coming or time to get a refund?
  19. Bip
    Bip New Member
    Oct 4, 2014
    What was this workaround that Bryan mentioned?
  20. Bryan Edmonds
    Jul 3, 2014
    240
    124
    How to use Roll Trim in the beta App: HERE
